07 trailblazer, maxlife 5w20 , 8800 mi, 188400
Wisconsin
Oil of curiosity, following the vendor rep from valvoline, he told me the Maxlife 5w20 is rated to 10,000 miles, so I pushed it to 8800 miles and sent in for oil analysis via Wix.
Here's what they said.
2007 trailblazer lt 4.2l
188400 on test.
Code
DATE REPORTED 15-Apr-19
WO NUMBER
031118
Miles on engine 188400
Oil Change 8842
Valvoline
Maxlife Full Syn
SAE 5W20
Metals (ppm)
Iron (Fe) 32
Chromium (Cr)
Lead (Pb)
Copper (Cu)
2
Tin (Sn)
Aluminium (Al) 10
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 13
Sodium (Na) 67
Potassium (K)
Additives (ppm)
Magnesium (Mg) 401
Calcium (Ca) 1603
Barium (Ba)
Phosphorus (P) 655
Zinc (Zn) 798
Molybdenum (Mo) 13
Boron (B) 12
Contaminants
Water (%)
Coolant No
Physical Tests
Viscosity (cSt 100C) 8.4
Physical / Chemical
Base Number (mgKOH/g) 2.2
DIAGNOSIS
Engine wear levels appear satisfactory for first sample.
Silicon level (dirt/sealant material) satisfactory. Water
content acceptable. Viscosity within specified operating
range. Action: As oil and filter(s) already changed,
resample next service interval to monitor and establish
wear trend
Have the same year Trailblazer and engine I take care of. Why are you running 5W-20 and not 5W-30? Right now im running 10w-30 Pennzoil from all my stash.
Also
Welcome to BITOG Buzz
Nice report for this winter run. But with summer coming, will you be running 5W30?
The formulations for these oils have been changing. So stay on top of them.
I did spec it out, but I followed what previous owner had written on the fan shroud.
I think on my oil change I'll bump it up to 5w30, so far since Feb when I did my last oil change I'm almost at 3000 miles, so it won't be in there long.
Looks good, but I would run 5W30 as that is what the manual suggests. The 4.2Ls are great engines. My dad still daily drives his 03 Trailblazer.
I just recently gave our '02 away. It had 233K on it. I always used M1 5w30 and changed it at 7500 along with the Purolator. Besides the water pump, that 4.2 is a great engine.
