Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
VOA - HCF-2, Eneos Import CVT Model H, Eneos ECO CVT
by Stucker21trt. 06/26/19 06:48 PM
2012 Mazda3 iTouring
by Kira. 06/26/19 06:46 PM
Blazer Chalet
by dishdude. 06/26/19 06:27 PM
So confused about Hemi oil
by TN Tracker. 06/26/19 06:20 PM
Gabby Chaves’ mobile oil change business
by Pat in Speedway. 06/26/19 06:03 PM
PUP 5w-30 - 2016 GS F - 5,051 miles
by Tiir. 06/26/19 05:41 PM
I-CAR Gold Class Car Wash...
by Vern_in_IL. 06/26/19 05:36 PM
Kia manual allows 5w20 and 5w30 but not 0w20?
by Whammo. 06/26/19 05:31 PM
Buy A Car...Get Freebies
by GrtArtiste. 06/26/19 05:09 PM
by Stucker21trt. 06/26/19 04:31 PM
Radar Dimax AS-8 Diamond in rough
by spiderbypass. 06/26/19 04:06 PM
icy hot additive for oils
by 1978elcamino. 06/26/19 03:33 PM
Why does diesel stink so much less than gas?
by atikovi. 06/26/19 02:29 PM
Mackay radiator hoses?
by atikovi. 06/26/19 02:21 PM
1962 Cub Cadet Original
by Phishin. 06/26/19 01:27 PM
2008 Yamaha VX 1100 oil filter choice
by ledslinger. 06/26/19 01:09 PM
GM's HD Truck Line $100k
by earthbound. 06/26/19 12:17 PM
Huge shark York Beach Maine
by LeakySeals. 06/26/19 12:05 PM
Soflonole27, Bungalowbill, jefferylhenry, dead_bird, mikem350
68501 Registered Users
116 registered members (AandPDan, 928, 53' Stude, ad244, Aero540T, 9050lx, 7 invisible), 2,084 guests, and 26 spiders.
Topics291,012
Posts4,996,970
Members68,501
Most Online2,967
Mar 10th, 2019
Thump/slap after rear pinion seal replacement #5079311
04/18/19 09:55 PM
04/18/19 09:55 PM
WI
HoosierJeeper Offline OP
WI
I took my Liberty in for Monday to get the rear pinion seal replaced since it was leaking (194k!) and got it back, no issues. Drove about 200 miles since then. Today it started making this noise that sounded like a spoon or something got caught in a rear tire, after about 10 miles it got super loud. I noticed when I let off the guess is when the sound happened, on the gas it was quiet so figure it's rear diff related. (nothing in the tires obviously). I dropped it back off at the shop tonight so he can look at it tomorrow. Any ideas on what it could be? The driveshaft felt normal going into the diff and I didn't see anything obviously wrong.
Thanks!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079318
04/18/19 10:04 PM
04/18/19 10:04 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
You're probably OK until it sounds like a fork is stuck in the tire.
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079338
04/18/19 10:27 PM
04/18/19 10:27 PM
WI
WI
I'd say it went from spoon to spork to fork to butcher knife stuck in the tire!
Seriously, it's very rotational, which lead me to think it was something in the tire. But the whole on gas/off gas thing rules that out and it was from the rear.
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079347
04/18/19 10:45 PM
04/18/19 10:45 PM
USA
oldhp Offline
oldhp  Offline
USA
Sounds like the pinion nut backed off.
2018 RAM 1500 3.6/8 speed.
2019 Dodge Charger SXT 3.6/8 speed.
"When others cut you down, remember where they came from."
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079406
04/19/19 01:46 AM
04/19/19 01:46 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Damaged axle bearing?
Anyway, take it back right away and have them make it right.
Re: Thump/slap after rear pinion seal replacement [Re: oldhp] #5079452
04/19/19 04:50 AM
04/19/19 04:50 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
That's my guess too. I had a 1974 C-10 and it showed your same symptoms when the nut worked its way loose.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079490
04/19/19 06:20 AM
04/19/19 06:20 AM
WI
WI
Would that have done damage to the axle? Or once he tightens it will it be ok?
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079535
04/19/19 07:12 AM
04/19/19 07:12 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I don't know how this diff is set up but the pinion depth may need to be checked/set. It needs a thorough inspection anyway so I would probably use someone else to do the job.
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079745
04/19/19 10:34 AM
04/19/19 10:34 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
Loose driveshaft strap. Thrown U joint cap.
sometimes the simple stuff does not get checked.
Rod
Re: Thump/slap after rear pinion seal replacement [Re: HoosierJeeper] #5079822
04/19/19 11:38 AM
04/19/19 11:38 AM
Va.
Piston_slap Offline
Piston_slap  Offline
Va.
I hope you got the same shop to replace it under warranty. That's a sorta important small thing. crzy
1994 Ford Econoline w/302 & 4R70W
Valvoline 10W-40, WIX Gold
Isotope U235
