First wax after paint job
by Audios - 10/18/19 02:31 PM
Fuel Mileage - Quick vs. Steady Acceleration
by onespiritbrain - 10/18/19 02:16 PM
Alternator, Battery Problem ?
by MasterSolenoid - 10/18/19 12:50 PM
Vaccum Oil Extractor
by ad244 - 10/18/19 11:50 AM
Mercedes C240 Engine Temperature
by NICAT - 10/18/19 11:20 AM
oil pressure went to 0 on the cummins
by motor_oil_madman - 10/18/19 11:01 AM
Renault at the edge of the abyss.
by PimTac - 10/18/19 10:39 AM
Power Washing
by buster - 10/18/19 10:02 AM
Contaminated fuel from fuel stations
by bonjo - 10/18/19 09:54 AM
TBN graph - is this a good way to look at OCI?
by TiGeo - 10/18/19 08:49 AM
$4 get peppercorns and a free grinder
by JLawrence08648 - 10/18/19 08:18 AM
Poll: Where do you purchase motor oil ?
by kstanf150 - 10/18/19 07:28 AM
Advantage of ethanol free fuel?
by mrdctaylor - 10/18/19 07:17 AM
2004 Cummins 480 CE Marine Engines
by jmichels - 10/18/19 06:29 AM
Deleted vs Non-Deleted UOA
by oakaro68 - 10/18/19 05:30 AM
3.2 V6 Cayenne oil help
by Abax25 - 10/18/19 04:16 AM
Can cops sit in the median with no lights on at night time?
by motor_oil_madman - 10/18/19 12:24 AM
Tequila009, JCunningham, TomStackhouse, Drinksprite, jmichels
69595 Registered Users
86 registered members (alarmguy, 2015_PSD, 69GTX, 2dogs, 28oz, 13 invisible), 2,281 guests, and 17 spiders.
Topics296,143
Posts5,092,135
Members69,595
Most Online3,532
Jul 30th, 2019
Help me identify this tie rod washer #5079270 04/18/19 08:40 PM
K
Klutch9 Offline OP
K
Replaced all 4 tie rods on the Fusion today. Pretty easy job, all considered. In the process, I found that on the inner end of the inner rod sits a rubber/metal washer. I have no idea what it's called, but you can see it in this picture next to the steering rack end of the inner tie rod:
[Linked Image]
Basically it sits on the collar of the inner rod where it threads into the rack. For clarity, this is NOT a lock washer like some cars use. From the looks of it, all it does it soften the impact when the steering goes full lock. The metal pieces on each side of the rubber are just there presumably to make the washer last longer. The reason I ask is because the passenger side washer was fully intact, whereas the driver side washer was mostly disintegrated. Only the 2 metal outside pieces remained with very little rubber in between. I left it there, as it can't hurt and would still soften the impact some. The parts I used (Moog problem solver) did not come with these washers. Am I on the right track here? The washer was only about 1/8" thick, and sticks out about the same as the collar on the rod does.
'11 Fusion SE 2.5L - 89k miles - HK 0w20 syn, Carquest Blue filter
'08 Sedona LX LWB 3.8L - 141k miles - Havoline HM 5w20, Carquest Red filter
Re: Help me identify this tie rod washer [Re: Klutch9] #5079302 04/18/19 09:25 PM
das_peikko Offline
I'd be flaming mad if it was me. I'm still kinda mad about it and it's not even my car. Moog would be getting a phone call from me.
Re: Help me identify this tie rod washer [Re: das_peikko] #5079304 04/18/19 09:39 PM
K
Klutch9 Offline OP
K
Truthfully, the only brand that comes with this washer is Motorcraft to my knowledge. No reason to be upset. Lots of instances like this out there, where in order to get one little washer/bushing/etc, you have to buy the OEM kit. Just the way it is.
Re: Help me identify this tie rod washer [Re: Klutch9] #5079481 04/19/19 06:03 AM
T
Trav Offline
T
They don't just cushion the rack movement but act as a lock limiter. We used to use them on BMW cars that ran oversized tires to limit the lock. They also protect the seals by not allowing 100% travel right up to the seal. They are probably only available from the dealer and must be installed to prevent seal damage and eventual rack leaks due to full lock (worst thing you can do to a rack).
Re: Help me identify this tie rod washer [Re: Klutch9] #5079644 04/19/19 08:58 AM
M
mazdamonky Offline
M
I would just go to the the nearest ford dealership and buy just the washers.
2018 mazda3 hatch 2.5 263 miles
1985 rx7 1.1 98k miles
2002 protege 220k miles
1985 rx7 with a 5.0 swap
2002 Protege 299k miles Girlfriend's
4 more running cars in yard not mentioned
Re: Help me identify this tie rod washer [Re: Trav] #5079663 04/19/19 09:09 AM
K
Klutch9 Offline OP
K
Trav, this car has electric power steering with no fluid, so I imagine that the seals are different than with a hydraulic system.
Re: Help me identify this tie rod washer [Re: Klutch9] #5079737 04/19/19 10:29 AM
bdcardinal Offline
Those washers are only sold with the inner tie-rod from Ford.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Help me identify this tie rod washer [Re: bdcardinal] #5079759 04/19/19 10:43 AM
K
Klutch9 Offline OP
K
What are those washers actually called, and what is their exact purpose?
Re: Help me identify this tie rod washer [Re: Klutch9] #5079766 04/19/19 10:51 AM
T
Trav Offline
T
It still has seals to prevent water ingress but its probably not as critical on an electric system.
Re: Help me identify this tie rod washer [Re: Klutch9] #5079777 04/19/19 11:03 AM
bdcardinal Offline
From the FSM:
"Retaining washer (Hydraulic Power Assist Steering (HPAS) only) (part of 3280 and 3332B service kit)"
It doesn't show in the illustrations in either the parts catalog or FSM. The 3280 is the Ford base number for an inner tie rod. The 3332 is the bellows boot and clamp kit.
Re: Help me identify this tie rod washer [Re: bdcardinal] #5079821 04/19/19 11:35 AM
bdcardinal Offline
To correct myself, its apparently with the bellows boot assembly also. Although we never sell those. Also obviously with a whole steering rack.
Re: Help me identify this tie rod washer [Re: bdcardinal] #5079852 04/19/19 12:02 PM
T
Trav Offline
T
Strange, he has an electric rack and he removed them from the old inners. It makes sense that the hydraulic rack uses it. shrug
