Thread Repair Question
by The Critic - 08/19/19 02:48 AM
Genuine Mercedes-Benz 229.5 5W-40 Engine Oil
by The Critic - 08/19/19 02:25 AM
Is it safe to use 100% synthetic
by Espada - 08/19/19 02:16 AM
Cobb Air Filter Cleaning
by The Critic - 08/19/19 01:58 AM
PCV side of the engine is cleaner
by OilUzer - 08/19/19 01:50 AM
Which is Better: Old or New Castrol Edge 0W-40?
by nielkfj - 08/19/19 01:18 AM
Discount Tire Warranty
by Maddog1337 - 08/19/19 12:26 AM
Mobil One Super Synthetic Euro 5W-40
by hellokitty - 08/18/19 11:26 PM
Help Me Search
by Gebo - 08/18/19 09:29 PM
2018 Camry Transmission Drain & Refill Procedure
by painfx - 08/18/19 09:11 PM
.325 pitch vs .375 pitch saw chain
by The_Eric - 08/18/19 09:04 PM
House buying opinions on houses.
by ram_man - 08/18/19 08:50 PM
How to get nails out of my driveway?
by Chris142 - 08/18/19 08:37 PM
Used cars imported from Canada to USA on the rise?
by BobsArmory - 08/18/19 08:28 PM
2010 Accord P1009 Code
by Phishin - 08/18/19 08:15 PM
Espada, samhainlimon, CrazyElf, mattkocanda95, HardCoreHawkFan
68995 Registered Users
22 registered members (billt460, 4WD, alchargo, 2015Corolla, d00df00d, edhackett, 3 invisible), 592 guests, and 24 spiders.
Topics293,497
Posts5,041,224
Members68,995
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: 205/45/17 Second Thoughts [Re: Panos] #5075366 04/15/19 06:41 AM
E
ET16 Offline OP
E
Originally Posted by Panos
Originally Posted by ET16
I'm thinking now that I should maybe go with 16 inch rims with 205/50/16 tires, or just stay with what I have.
Any opinions?
16' rims and 50 sidewall is all you need for the streets to get that sporty feeling on your nice sedan car.
I would stay in the safer side of comfort and rim protection.
You 'll notice a drastic difference from 195/60/15 going into a 205/50/16 setup.No need to go to the extremes and add more weight on your wheel hubs with the 17"s.
In retrospect, I should have gone this route, but I've already bought 17s and now have to deal with sunk costs. I can still sell the 17s, of course.
Re: 205/45/17 Second Thoughts [Re: slacktide_bitog] #5075399 04/15/19 07:19 AM
Q
Quattro Pete Offline
Q
Originally Posted by slacktide_bitog
There are still some good tires made for the size 195/60-15 smile
Yeah, but none of them are particularly high perfomance. I am not seeing any summer tires in this size, and not even UHP A/S on TireRack.
However, if the OP is able to mount 205/55 tires on his 15" rims, then there are several UHP summer options available, for example Yokohama s.Drive. This ought to firm up steering response quite a bit.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: 205/45/17 Second Thoughts [Re: Quattro Pete] #5075585 04/15/19 10:35 AM
slacktide_bitog Offline
The Vredestein Sportrac 5 is available in 195/60-15 smile
Re: 205/45/17 Second Thoughts [Re: ET16] #5075631 04/15/19 11:17 AM
L
litesong Offline
L
I bought some 17 inch rims for my Saab 9-3. It has 15 inch rims now with 195/60/15 tires, but I wanted a little better handling.
The 17 inch rims should take 205/45/17 tires to achieve the original diameter. Any opinions?
Get larger diameter tires. From another thread, I wrote:
My 2008 Hyundai Accent & 2013 Elantra now have bigger wheels/tires & I love them. Both the Accent & Elantra now have 55,000+ miles total distance traveled on the larger set-ups. The Accent tires (from 14inch to 15inch wheels) are 2 inches taller than standard. The Elantra tires (from 15 inch to 17 inch & 18 inch wheels) are as much as 2.7 inches taller than standard..... The 17's can have aspect ratios(AR) up to 55. I've had AR's of 45 on the 18's, but they should handle 50's. My recommendation is to get several sizes & types of wheels, so you can have fun, changing your wheel style, say when you change tires. If you like distance traveling a lot, keep your aspect ratio between 45 & 65 (& drive careful on the 45's). 40 aspect ratio & lower are only for local travel, only on smooth roads & watch like a hawk for potholes. My recommendations of different wheel sizes is because I buy used wheels/tires, can easily afford the various sizes AND drive gently. If you don't drive gently, you'll put more strain on your suspension components, which is a good way to make long term friendships with car repairmen.
With the bigger wheels/tires tho, snow chains won't fit. So keep your old wheels/tires ready for snow.
Re: 205/45/17 Second Thoughts [Re: ET16] #5075679 04/15/19 12:16 PM
G
geeman789 Offline
G
I would just keep the 17's , maybe put on a SLIGHTLY taller tire, like a 215/45 -17 ( 24.6 inches tall) or a 205/50 -17 ( 25 inches tall ) , and see how it feels ...
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: 205/45/17 Second Thoughts [Re: geeman789] #5079256 04/18/19 08:26 PM
M
mightymousetech Offline
M
Originally Posted by geeman789
Originally Posted by rooflessVW
I would not consider 205/45R17 to be low profile.
Tires have come a long way, and the car will ride just fine. If you bought decent wheels, you're not going to bend or crack one, either.
A 205/45 is not low profile ... really ?
You must live where there is no winter, and the " paved ... " roads are still sort of smooth ... not pot holed and weather cracked from spring thaw.
I worked at a German car dealer, and we would see 5 - 6 cars PER MONTH come through with bent wheels, mostly oem, and sidewall bubbled tires, all with low profile tires ...
Buyer beware ...
45 series really is not that low anymore, I often see cars with 45 series winter tires, with much lower series (35 or 30) summer tires.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, Castrol 0W40, MT-LV
Re: 205/45/17 Second Thoughts [Re: mightymousetech] #5079279 04/18/19 08:54 PM
G
geeman789 Offline
G
Tell that to the pothole that just destroyed your balloon like 45 series winter tire and wheel ... frown
Re: 205/45/17 Second Thoughts [Re: ET16] #5079908 04/19/19 12:52 PM
E
ET16 Offline OP
E
Since I have the wheels now, I am shopping for tires.
I am looking at Nexen N7000 Plus for $258 (4) and Falken Ziex ZE950 for $272 .
Page 2 of 2 1 2
