Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
94 registered members (2003f7, ABN_CBT_ENGR, 4WD, 2010Civic, 72te27, Ag76, 10 invisible), 2,179 guests, and 36 spiders.
Topics306,288
Posts5,289,658
Members71,618
Carburted car runs fine while it's day, stutters at night #5078850 04/18/19 01:36 PM
G
Glam_Stachee Offline OP
G
It's like a bad superhero. Runs fine and dandy during the day but then if I try to run it at night it constantly stutters in 1st and 2nd gear at lower RPMs, I know that's normal but it doesn't happen during the day. Temperature doesn't affect the stuttering, could be freezing during noon it will run just fine, and could be warm at night and it still stutters, and car does it both when the engine is cold and warmed up.
Carb was just tuned up, I cleaned it, changed the air filter and even poured in STP fuel cleaner to see if that would fix it, still does it.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5078865 04/18/19 01:44 PM
Duffyjr Offline
The only difference between day and night would be your lights, does it do it at night if you turn the headlights off.
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: Carburted car runs fine while it's day, stutters at night [Re: Duffyjr] #5078917 04/18/19 02:31 PM
G
G
Yup, still does it, tried turning on the lights during the day, even brights, doesn't do it. And I don't see how electronics could affect stuttering in any way.
Only time it didn't do this is after I poured in the STP into the fuel and a week later when I filled up the tank again, then it did run fine all the way to my destination, but again when I turned the car back on it started again.
I am starting to think the gas I'm using might be affecting it, since the one time it didn't stutter I filled up at the more expensive gas station with "supposedly" better quality gas. I might even try switching from 95 to 98, maybe that will help.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5078936 04/18/19 02:45 PM
spasm3 Offline
What car? What type of ignition system? I'd look at everything spark plug wires, cap and rotor esp. If it has points, check them, file and gap them. Might try a new condenser. Day night thing does not make sense unless its a load like lights , a/c that the alternator can't handle and lowers power to the coil, but thats a stretch.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Carburted car runs fine while it's day, stutters at night [Re: spasm3] #5078944 04/18/19 02:52 PM
G
G
It's a 1991 Peugeot 309. Don't know what kind of ignition system but it's definetly different from my previous cars. Doesn't have points since it's not that old. And I can conclude it's not a load thing as it runs fine with the light on during the day and still stutters during night.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5078951 04/18/19 02:56 PM
P
Pelican Offline
P
Possibly humidity as it's generally more humid at night, I'D CHECK THE FUEL-AIR MIXTURE
Re: Carburted car runs fine while it's day, stutters at night [Re: Pelican] #5078955 04/18/19 02:59 PM
G
G
So far it's the theory most people have brought up when I asked them, but honestly I just did the carb not 5 months ago and can't be asked to do it again.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5078980 04/18/19 03:25 PM
javacontour Offline
Are you sure it's an engine issue?
Could it be a drive line issue that manifests during a more humid night?
Clutch chattering or skipping when it's damp that you don't see during more dry conditions?
If it is an engine issue, I'm thinking marginal HT leads / spark plug wires depending on which version of English car part names you use.
I'd certainly look into cap, rotor, wires/leads and maybe even the plugs.
If it all checks out, and voltages are good with the lights on as others have suggested, start looking for other issues such as a chattering clutch or similar.
network down, IP packets delivered via UPS -BOFH
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5079008 04/18/19 03:48 PM
K
Kawiguy454 Offline
K
Check spark plug wires and boots for dry/cracking or arc tracks. If they're old replace them. Check engine ground strap and ignition electronics to ensure a good clean ground connection. Misfire can only be fuel or ignition and you've eliminated fuel. The electronics with a nominal ground wont fire well and old wires/boots can arc across their surface.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5079012 04/18/19 03:53 PM
P
Popsy Online Content
Online Content
P
What about humidity ?
Edit : way too late smile
Carb adjustement is finicky on these
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, M1 TDT 5W40 | Colt Ralliart, 300V 0W40
Re: Carburted car runs fine while it's day, stutters at night [Re: javacontour] #5079056 04/18/19 04:36 PM
G
G
Not really, not much more complicated than my old cars, except the stupid air filter which takes forever to take off. I'm just really bad at adjusting carbs and so far it runs good half the day.
Possible that it's the something to do with the spark plugs. I haven't touched them since I got the car, but only because I don't have a socket for removing them anymore, gonna have to get one of those first.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5079070 04/18/19 04:49 PM
P
Online Content
P
Not complicated, just that it tends to need adjustment often. Again my experience based on a 205 so I don't know, more space under the 309's hood so maybe less prone to need adjustment ?
Also there was two types of carbs on these, Solex and Weber. Solex apparently harder to tune ?
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5079146 04/18/19 06:11 PM
E
eljefino Online Content
Online Content
E
Stuttering's an ignition issue.
I replaced the factory carb on my 1985 dodge plow truck last year. The new one works great. They are a wear item that wears out, and all the adjusting in the world won't make up for that.
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5079251 04/18/19 08:20 PM
Dinoburner Offline
Had a similar problem many years ago and what we did was open the hood in a dark area and watched tiny sparks flash intermittently on the plug wires; Next day we misted the wires and the engine shook and stalled.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Carburted car runs fine while it's day, stutters at night [Re: Glam_Stachee] #5079253 04/18/19 08:23 PM
R
Rhymingmechanic Offline
R
Ignition would be my guess, too, if it gets significantly more humid at night.
Have you ever opened the hood while it's running at night? If the plug wires are really bad, you might see them arcing in the dark.
