Maxlife ATF for +4 application
by ZraHamilton. 05/26/19 03:43 PM
PL24651 Purolator One 6K Miles
by kstanf150. 05/26/19 02:38 PM
Inner tube for 700c beater
by MrQuackers. 05/26/19 02:34 PM
New to the cartridge oil filter party....
by ZZman. 05/26/19 11:49 AM
HF dual action polisher
by buck91. 05/26/19 11:22 AM
Virgin Motorcraft 820 Cut Open
by kstanf150. 05/26/19 11:11 AM
M1 EP for '19 F150 3.5 EB
by dseg42. 05/26/19 10:02 AM
Get New HVAC or Keep Old?
by tc1446. 05/26/19 09:48 AM
HF torque wrench wore out
by eljefino. 05/26/19 09:31 AM
garage fridge problems
by zrxkawboy. 05/26/19 08:35 AM
Sudden Unintelligence Syndrome
by AlienBug. 05/26/19 08:27 AM
Cutting Wet Grass
by Snagglefoot. 05/26/19 08:20 AM
Dealer Repair exposed a yellow wire?
by Datarock. 05/26/19 07:14 AM
Transmission Pan Gasket?
by mctmatt. 05/26/19 07:12 AM
Gas Mileage
by Al. 05/26/19 07:11 AM
Why HTHS 3.0 Minimum Is Preferred By Many ?
by ChrisD46. 05/26/19 06:14 AM
Fram Extra CA7597
by mcwilly. 05/26/19 03:26 AM
Carbon knock or piston slap
by i6pwr. 05/26/19 03:11 AM
brycam00, Kingkopra, rschwartz33, Rhoover, chirolla
68214 Registered Users
97 registered members (53' Stude, ARCOgraphite, 08z06, 1WildPig, ABomb369, 928, 14 invisible), 2,203 guests, and 26 spiders.
Topics289,429
Posts4,969,343
Members68,214
Most Online2,967
Mar 10th, 2019
1994 Chevy P30 (Fleetwood Southwind Storm) Valvoline VR-1 20w-50 #5078908
04/18/19 02:18 PM
04/18/19 02:18 PM
Ca-Wa-Japan
udidwht Offline OP
udidwht  Offline OP
Ca-Wa-Japan
Mileage on RV - 57,990
Miles driven on oil - 3,720
Duration of oil use - 14 months
Sample date - 09/18/2018
Report date - 10/08/2018
https://www.dropbox.com/s/qpzub1q70cn3c77/RV%207.4L%20oil%20report.pdf?dl=0
Was on the road when I changed the oil and did not have the preferred viscosity of 10w-30 available (went to 3 diff. places).
1994 Fleetwood Southwind Storm 28ft
P-30 454 TBI w/4L80E trans
1972 VW Westy hardtop (Type-4 2056cc)
2003 Toyota Highlander 2.4L
Re: 1994 Chevy P30 (Fleetwood Southwind Storm) Valvoline VR-1 20w-50 [Re: udidwht] #5078910
04/18/19 02:24 PM
04/18/19 02:24 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Great report on your 454, iron is CRAZY low for a 454 in a passenger car let alone in a P chassis. Copper is likely from oil cooler.
I'd be very pleased if this was my 454, excellent report.
Luke
Re: 1994 Chevy P30 (Fleetwood Southwind Storm) Valvoline VR-1 20w-50 [Re: udidwht] #5078926
04/18/19 02:39 PM
04/18/19 02:39 PM
Canada
addyguy Offline
addyguy  Offline
Canada
Only the copper and lead are elevated for the miles, could it be you have worn through the babbit layer on the bearings, and are down to the copper?
It sheared down the 50-weight to a 40-weight; what if in the past it sheared 30-weights down to 20 weights, and the bearings have been wearing out?
A hard-worked 454 would wear out the bearings like that.
2010 Kia Soul 2U - 2.0L I-4, auto; 142k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: 1994 Chevy P30 (Fleetwood Southwind Storm) Valvoline VR-1 20w-50 [Re: addyguy] #5078958
04/18/19 03:02 PM
04/18/19 03:02 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I would expect to see elevated iron with copper if that was the case, these Gen V 454s have a pretty robust oil cooler in a P chassis. I wouldn't suspect bearing wear here.
Luke
Re: 1994 Chevy P30 (Fleetwood Southwind Storm) Valvoline VR-1 20w-50 [Re: udidwht] #5078978
04/18/19 03:23 PM
04/18/19 03:23 PM
Ca-Wa-Japan
udidwht Offline OP
udidwht  Offline OP
Ca-Wa-Japan
Been told and seen (other oil reports) that the BBC 454 engine it's fairly typical for the copper level to go up/down over the miles.
The oil cooler is huge in these P30 RV chassis (same size as the A/C condenser. In fact, they are a combined but separate units (part). Sit directly in front of the radiator and nearly the same size.
Pic of A/C-oil cooler.....
https://www.dropbox.com/s/oilh4kcssl2dkcn/IMG_0411%5B1%5D.JPG?dl=0
1994 Fleetwood Southwind Storm: https://www.dropbox.com/s/pc1wtu2058d5xi0/20180530_132027%5B1%5D.jpg?dl=0
