Oil change before car sitting 1 year?
by clarkflower - 08/24/19 12:47 PM
Havoline Smart Change on RB
by Mad_Hatter - 08/24/19 11:54 AM
TFL Truck testing Rotella Gas Truck.
by A_Harman - 08/24/19 11:34 AM
01 Nissan Sentra 2.0 AC issue
by Mark72 - 08/24/19 11:21 AM
I should have bought that Daewoo
by 5AcresAndAFool - 08/24/19 10:24 AM
Any one tried one of these ?
by WyrTwister - 08/24/19 10:02 AM
Correct Temps to Check ATF Fill
by Gebo - 08/24/19 09:48 AM
Wonder how much $ ice cream trucks make?
by Chris142 - 08/24/19 09:45 AM
Like tinkering on cars? Start young.
by BMWTurboDzl - 08/24/19 09:14 AM
Pumkin
by Eddie - 08/24/19 09:02 AM
Any GTO Owners On Here?
by oilpsi2high - 08/24/19 08:34 AM
Does Anyone Sim-Race?
by RayCJ - 08/24/19 06:56 AM
Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
87 registered members (bchannell, AZjeff, ArrestMeRedZ, aquariuscsm, 13 invisible), 2,499 guests, and 28 spiders.
Topics293,730
Posts5,045,774
Members69,048
Most Online3,532
Jul 30th, 2019
Accord AC Issue #5078687 04/18/19 10:54 AM
M
maverickfhs Offline OP
M
On recently acquired 07 Accord, AC is throwing warm air, it gets slightly cold but then again it's warm.
Could it be that system needs a charge? Or can be something else? Appreciate any advice and help. thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Accord AC Issue [Re: maverickfhs] #5078698 04/18/19 11:01 AM
J
JeffKeryk Online Content
Online Content
J
Do a charge and see what happens. It worked for out low mileage 1998 Accord LX.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Accord AC Issue [Re: maverickfhs] #5078700 04/18/19 11:02 AM
J
JMJNet Offline
J
You have to measure the refrigerant pressure.
There is a tool called pressure gauge specifically made for checking AC system.
There is no way to determine from your information given to us, all we know is that the AC is not working.
If you ask here, I suspect, you don't have the tool.
So you need to buy it or bring it to someone who has the tool and knowledge to use it.
That someone can be a mechanic shop or a friend.
So, if there is no pressure, why?
Is there leaks, or the compressor gave up or the clutch in the compressor give up, etc.
For leaks, we need to investigate where.
You can use sniffer or put dye on the refrigerant then use a special uv light to see it.
  • 2017 Toyota Sienna
Re: Accord AC Issue [Re: maverickfhs] #5078705 04/18/19 11:06 AM
M
M
I think some of the auto stores have a loaner for AC gauges and I can get those to test the system, have seen some youtube videos on it.
Yes, I do not have the tools(gauges) .
Re: Accord AC Issue [Re: maverickfhs] #5078709 04/18/19 11:13 AM
M
mattwithcats Offline
M
On systems at least ten years oil, that are getting cool, but slowly, try adding a oil charge.
This is 1 ounce Pag oil, 1 ounce R134a, and 1 ounce “Performance Enhancer”...
Only do this once in the life of the system, or you will drown it!
https://www.walmart.com/ip/Ac-Pro-R-134a-PAG-100-Oil-Charge-with-Ice-32-Oil/509467516
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Accord AC Issue [Re: maverickfhs] #5078761 04/18/19 12:09 PM
Chris142 Offline
Could be low. If it is it has a leak. Could be a bad expansion valve,bad pressure switch etc. What are the high and low side readings along with the ambient temp?
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Accord AC Issue [Re: maverickfhs] #5078880 04/18/19 01:58 PM
V
vw7674 Offline
V
A/C do lose refrigerant through compressor shaft seal over time, most top-off starter kits come with a handy gauge to tell you when to
charge the system while the engine is on powering the compressor. It's a 1-2-3 kind of procedure. Re-charged a warm air
blowing ancient Infiniti last summer & it's still blowing cold air today. You do need to know how many ounces are needed to
get to full capacity. (the Infiniti was 16.+.) sometimes you need to buy the kit with gauge plus an extra bottle to fully charge the system.
Re: Accord AC Issue [Re: maverickfhs] #5078888 04/18/19 02:01 PM
M
madRiver Offline
M
A simple issue common is bad ac relay. I believe it’s around $10 for a new one.
Re: Accord AC Issue [Re: madRiver] #5078911 04/18/19 02:24 PM
M
M
Any idea what are the symptoms of it?
Re: Accord AC Issue [Re: maverickfhs] #5078969 04/18/19 03:08 PM
M
M
Usual source of leaks are the Schrader valves...
These can be replaced without opening the system,
but specialized tools are needed..
2009 Smart Pure
Re: Accord AC Issue [Re: maverickfhs] #5079558 04/19/19 07:44 AM
W
wag123 Offline
W
Honda had a problem with A/C compressor clutches during that era. They have a warranty extension for this problem on some models. There are several Youtubes from people showing how to diagnose and repair the problem on the cheap.
Re: Accord AC Issue [Re: maverickfhs] #5079568 04/19/19 07:55 AM
M
mk378 Offline
M
Check if the compressor is staying engaged. If the compressor doesn't engage it could be the relay or other electrical problem. If the compressor is turning but it doesn't cool, then you need to get pressure readings.
Also the condenser fans should run continuously or most of the time (depending on system design) when the car is sitting still with the A/C on.
