New pennzoil rebate 7/16-12/31/19
by pdxglocker9mm. 07/17/19 03:11 AM
'82 BMW 733i M30 - Which Oil
by TXCarGeek. 07/17/19 02:07 AM
Aother MEGA score+Free Mobil 1 oil change
by GMguy84. 07/17/19 12:39 AM
I think I need therapy...
by tony1679. 07/16/19 11:53 PM
Hellcat engine in a Miata
by hate2work. 07/16/19 09:59 PM
Alignment shop questions
by Jeff999. 07/16/19 09:45 PM
ZF Aftermarket, Why Change Your ATF
by BMWTurboDzl. 07/16/19 08:10 PM
Goodyear Wrangler DuraTrac
by NHRATA. 07/16/19 08:05 PM
5 qt Castrol GTX Magnatec 5w-30 $10.30 on Amazon
by gallydif. 07/16/19 07:59 PM
My new rig - 1987 Ford Econoline 27' Glendale RV
by caprice_2nv. 07/16/19 07:44 PM
Air Compressor OCI?
by Vern_in_IL. 07/16/19 07:35 PM
Looking for an SUV
by dgunay. 07/16/19 07:29 PM
Castrol GTX Magnatec 5w30
by Envoyguy. 07/16/19 07:21 PM
2019 Subaru Dual X-Mode
by buster. 07/16/19 06:36 PM
Wear Metal Max?
by tsm750. 07/16/19 05:54 PM
Harbor Freight 25% off Thurs - Sunday
by JC1. 07/16/19 05:52 PM
80% Furnace exhaust silencer?
by PandaBear. 07/16/19 05:10 PM
Pennzoil Ultra on Sale
by Nyati. 07/16/19 04:39 PM
Not All Mid-Grade Blended At the Pump
by RayCJ. 07/16/19 04:30 PM
MBhuntington, captainfloss, Lyndol, Belczek, Bronco628
68681 Registered Users
22 registered members (Ammofirst, DaleRider, David1, Deontologist, alcyon, 2 invisible), 703 guests, and 17 spiders.
Topics291,972
Posts5,014,300
Members68,681
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Beware of tampering [Re: SHOZ] #5078392
04/18/19 02:25 AM
04/18/19 02:25 AM
PA
Gasbuggy Offline
Gasbuggy  Offline
PA
Send a sample to blackstone
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: Beware of tampering [Re: Gasbuggy] #5078535
04/18/19 08:01 AM
04/18/19 08:01 AM
Illinois
SHOZ Offline OP
SHOZ  Offline OP
Illinois
I'm already out $13 and am quite certain it is not as labeled.....
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Beware of tampering [Re: atikovi] #5078541
04/18/19 08:04 AM
04/18/19 08:04 AM
Valencia, CA
Richie Offline
Richie  Offline
Valencia, CA
Been happening more and more.
Originally Posted by atikovi
Somebody changed their oil, filled the jug with the old oil and returned it for a refund.
Re: Beware of tampering [Re: Greggy_D] #5078549
04/18/19 08:11 AM
04/18/19 08:11 AM
Texas
4WD Offline
4WD  Offline
Texas
Originally Posted by Greggy_D
I check every single plastic seal before I buy.
Same ... and look at the sight window - at least you'd see dirty oil that way - maybe not with this slickster means ...
Of course the foil seal or no deal (it's got to go back then) ...
Knock on wood - not burned yet ...
Re: Beware of tampering [Re: SHOZ] #5078563
04/18/19 08:23 AM
04/18/19 08:23 AM
PimTac Offline
PimTac  Offline
Some brands are easier to detect tampering. Valvoline’s new jugs with the clear cap that shows the seal underneath is great. Chevron’s new Havoline Smart Change should show any tampering right away.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Beware of tampering [Re: Kestas] #5078753
04/18/19 11:58 AM
04/18/19 11:58 AM
Perris, CA
Anduril Offline
Anduril  Offline
Perris, CA
Originally Posted by Kestas
Pretty slick substituting hydraulic fluid for the oil, if that's what happened. That would pass scrutinization by any clerk.
But the broken seal should not have.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Beware of tampering [Re: SHOZ] #5078815
04/18/19 12:55 PM
04/18/19 12:55 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Thanks for the heads up. I’m often not as careful as I should be with such things. I’m a “grab it and go guy”
Re: Beware of tampering [Re: SHOZ] #5078878
04/18/19 01:57 PM
04/18/19 01:57 PM
California
DGXR Offline
DGXR  Offline
California
Here's the rub: if you break the ring and remove the cap in order to be sure the foil seal is intact, you cannot return the product. So be sure you are buying something that you will definitely be using.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Beware of tampering [Re: DGXR] #5078901
04/18/19 02:10 PM
04/18/19 02:10 PM
PimTac Offline
PimTac  Offline
This is good advice but these gamers know how to make that cap look and feel sealed. They are conniving critters. If the cap is a solid color like most are then that adds to the difficulty of checking the internal seal.
Why the oil companies haven’t all gone to transparent caps or used a shrink wrap on the outside of the cap is baffling.
2017 Mazda CX5
Roki OEM filter.
Re: Beware of tampering [Re: Cujet] #5079027
04/18/19 04:04 PM
04/18/19 04:04 PM
Stillwater, MN
road_rascal Offline
road_rascal  Offline
Stillwater, MN
This. I just bought 3 jugs of Delo 400 XSP 5w/40 for my boat and ATV the other day and didn't check the cap before leaving WM. Fortunately they were all intact.
2012 Toyota Rav4 V6 4WD (87,000 mi)
2018 Chevy Equinox 1.5T (15,000mi)
Re: Beware of tampering [Re: JLTD] #5080442
04/20/19 06:07 AM
04/20/19 06:07 AM
sw ohio
willbur Offline
willbur  Offline
sw ohio
Originally Posted by JLTD
Oil buyer beware at WM....recurring theme.
Another reason I'm not inclined to go there for my oil.
Not just oil. I checked a gallon container of Zerex Asian Blue. It had been opened and refilled with visibly darker used blue coolant. I check everything from WM now.
Re: Beware of tampering [Re: SHOZ] #5080824
04/20/19 02:03 PM
04/20/19 02:03 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Yeah, and when you return it they look at you like you're the one who swapped it. Honesty is becoming scarcer.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Page 2 of 2 1 2
