Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
OE AC COMPRESSOR?
by FA_WRX. 05/23/19 09:08 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
134 registered members (2003f7, 28oz, 53' Stude, 2strokeNorthstar, 21 invisible), 2,233 guests, and 25 spiders.
Topics289,300
Posts4,966,508
Members68,181
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Remote transmission filter newbie questions #5078260
04/17/19 09:31 PM
04/17/19 09:31 PM
OK
Zahndkile Offline OP
OK
I just recently replaced my 2002 chevy tahoe transmission and would like to make it last. I am planning some cooling system upgrades and thought i might add a remote spin on filter.
My question is would an engine oil filter be a good choice for a remote transmission filter?
The filter i had in mind is Mobil M1-206a or equivalent Purolator boss.
The reason i chose those filters is that they are my engine oil filter of choice and they are included in the 5qt sales on M1 oil that i use. My engine uses more than 5 qt per change so i double up and get 10qt and 2 filters for less than the usual price for the oil alone. So i have a spare filter that could be used on the transmission.
Efficiency for the M1 filter is listed as 99%+ @ 30 micron.
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078276
04/17/19 09:44 PM
04/17/19 09:44 PM
The land of USA-made Subies!
SubieRubyRoo Offline
I'd just use a Magnefine, which is designed for what you're wanting to do. Plus, no need to buy a remote mount, just cut the return line, slip on 2 clamps, and stick the filter in.
Sure, you CAN do what you're proposing, but should you?
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078303
04/17/19 10:17 PM
04/17/19 10:17 PM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Your idea about using a filter head and a large filter will be a better option in the long run.
2015 F150 2.7
2018 F350 6.2
Re: Remote transmission filter newbie questions [Re: SubieRubyRoo] #5078304
04/17/19 10:17 PM
04/17/19 10:17 PM
OK
OK
That wasnt really my question. I dont like hose clamps. And the M1-206a comes nearly free. So if it would filter well and not have any problems i might do it.
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078319
04/17/19 10:30 PM
04/17/19 10:30 PM
thumbsup
Re: Remote transmission filter newbie questions [Re: CT8] #5078321
04/17/19 10:32 PM
04/17/19 10:32 PM
OK
OK
That was my thought i am just having a hard time deciding on a filter to use.
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078334
04/17/19 10:44 PM
04/17/19 10:44 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Any oil filter the size of a FL-1A or PH8A ("Generic Ford V8" size oil filter) will last you the life of your vehicle.
YES - I am serious!
I use a Baldwin BT839-10 (common 10 micron hydraulic filter) on a generic "log splitter" filter mount (also extremely common and very generic) as a trans filter on my F150.
If you ever cut them open after removing and see just how clean they are inside, you'll quickly realize that changing them regularly is a waste of time and money.
I think I have about 80,000 miles on my current one. I'll not change it - ever - unless it's time to rebuild the trans.
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078339
04/17/19 10:49 PM
04/17/19 10:49 PM
Vancouver, BC Canada
Cdn17Sport6MT Offline
I recommend NOT using an in-line filter; rather, use a very tight filter media bypass filter, and add-in an aux ATF cooler downstream of the in-rad cooler. When I say "tight" I mean 2 microns of filtration.
I have an NTF ATF-09 unit, which is made in Holland or Belgium. There is also the newer AL-09 unit.
I attach some info...
Also, one graphic gives an alternative. I don't know what it's filtration value is though. I note that the NTF units, though, are 2 microns by way of filtration - and that: i) really reduces the bypass flow across the cooler lines (that is actually good... in that it does not rob too much cooling action); and ii) it really brings the filtered quality of the ATF to spectacular (good) levels... perhaps even better than what is new-in-the-bottle.
Final point: the progression of the Company is / was: Eagle Picher NTZ; then NTZ; and then (currently) NTF. Same products, all of the while.
Attached PDF document
Mazda6 GX (Sport in the 'States), 6MT, 2017
Moto Guzzi 850 T5 (Euro version), 1985
Honda Civic Si (EX 2 dr. in the 'States), A/T, 1997
Toyota Camry CE, 5MT, 1999
VW (Type2) Kombi, 4MT, 1979
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078353
04/17/19 11:34 PM
04/17/19 11:34 PM
NY
joegreen Online content
joegreen  Online Content
NY
If you look up the flow rating of the filters and compare that to the flow rating of the atf you will see engine oil filters are more than adequate. Also i would like to point out toyota seems to favor flow over filtering as some of there transmissions just use a wire mesh screen. I wouldn't be to concerned about the micron rating of the filter as anything will be better than whats on there now.,
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Remote transmission filter newbie questions [Re: joegreen] #5078357
04/17/19 11:47 PM
04/17/19 11:47 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by joegreen
...............[pretty much all] transmissions just use a wire mesh screen. I wouldn't be too concerned about the micron rating of the filter as anything will be better than whats on there now.,
Pretty much every transmission "filter" I have ever seen in my entire life was a glorified "rock catcher".
I figured with 10 micron (Baldwin BT839-10) - - I was doing the trans a huge favor.
Re: Remote transmission filter newbie questions [Re: joegreen] #5078366
04/18/19 12:20 AM
04/18/19 12:20 AM
OK
OK
One reason i want better filteration is the 4l60e has a valve (torque converter clutch isolator valve I believe its called) that whares out and I believe the main reason is particles in the oil in the low Micron range. So i think keeping the oil clean will help prevent that valve from wearing which is a major killer of non abused 4l60e transmissions.
The 4l60e has a bad name and i belive the biggest reason other than abuse is fear of clean fluid. So i aim to be able to at 300,000 + miles say yep this is what full fluid changes and clean fluid does to a transmission.
Sorry for the rant. 😄
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078369
04/18/19 12:27 AM
04/18/19 12:27 AM
I finally found what I was looking for... a White Paper on the impacts of ATF cleanliness on A/T life expectancy. See attached.
A bit dry-reading, i.e. a scholarly article, but in my view something that really corroborates the whole claim of why we want really low-micron filtration for an A/T.
Swarf circulating in the ATF wears the valve body out, it wears out the rolling-element bearings... roller, ball, and Torrington, it worsens the wear of the steels, etc...
We all want to maximize A/T life... as they are expensive to fix... or in some cases, upon failure - they efffectively "total" a car from an economic perspective.
10.1.1.547.4083.pdf (21 downloads)
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078461
04/18/19 06:19 AM
04/18/19 06:19 AM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I second the Magnefine. The bulk of the crud I find in a Magnefine filter (when I take it apart) is metal particles clinging to the magnet and they form kind of a paste. There is very little in the filter media.
2015 Ford F250 w/Powerstroke
Re: Remote transmission filter newbie questions [Re: Zahndkile] #5078477
04/18/19 06:39 AM
04/18/19 06:39 AM
New Hampshire USA
Dinoburner Offline
Dinoburner  Offline
New Hampshire USA
Ten years ago after having the TH 400 rebuilt for the 77 Chev in my sig the shop manager said to install the inline filter they supplied in the return line and leave it there for 1500 miles then remove it and not to replace it which i did. This truck is now a summer toy which I occasionally hammer on. Not being a worrier I`m fine without the additional filter.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Remote transmission filter newbie questions [Re: Cdn17Sport6MT] #5078639
04/18/19 09:50 AM
04/18/19 09:50 AM
OK
OK
Cool find. Thank you for posting.
Page 1 of 3 1 2 3
