Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
OE AC COMPRESSOR?
by FA_WRX. 05/23/19 09:08 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
131 registered members (2003f7, 28oz, 53' Stude, 2strokeNorthstar, 18 invisible), 2,225 guests, and 25 spiders.
Topics289,300
Posts4,966,493
Members68,181
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Using red RTV gasket maker instead of a real gasket when replacing thermostat? #5078242
04/17/19 09:14 PM
04/17/19 09:14 PM
Canada eh
PotatoFarmer77w Offline OP
Canada eh
Hi all,
I have some left over Permatex High-Temp Red RTV Silicone gasket maker when I replacing the rear diff cover few years back. Now I’m going to replac the thermostat and just want to know if I can use this stuff as a gasket for the housing. On the package and the website it’s “recommended for thermostat housings” but I just wanna double check to make sure. The vehicle is a 95 Chevy k1500 with the 5.7 v8
Here’s the link:
https://www.permatex.com/products/g...matex-high-temp-red-rtv-silicone-gasket/
1995 Chevrolet K1500 5.7 v8 - 333000km
2007 Ford Ranger 2.3 I4 - 100000km + 2007 Froest River Flagstaff Tent Trailer smile
2016 Mazda 3 2.0 I4 - 50000km
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078256
04/17/19 09:28 PM
04/17/19 09:28 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Not a problem. Make sure your bead size is what they spec and follow the directions. Make sure the surfaces are totally clean. smile
If you want the job done right......do it yourself.
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078257
04/17/19 09:29 PM
04/17/19 09:29 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Clean both parts so that there is no oil. Put your goo on and finger tighten the bolts. Let it sit a few hours then final tighten them and add your coolant.
Works well. Many new cars dont use a gasket for things like this. Just goo as you described.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078279
04/17/19 09:50 PM
04/17/19 09:50 PM
The Motor City
Kestas Online content
Global Moderator
Kestas  Online Content
Global Moderator
The Motor City
I prefer to make my own thermostat housing gaskets.
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: Kestas] #5078288
04/17/19 09:58 PM
04/17/19 09:58 PM
out there
spasm3 Offline
spasm3  Offline
out there
Thats pretty cool! Share how you do it!
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: spasm3] #5078295
04/17/19 10:10 PM
04/17/19 10:10 PM
Georgia
MParr Offline
MParr  Offline
Georgia
I’ve made thermostat housing gaskets out of the cardboard box the thermostat came in. You cut the box a bit larger than the housing. Take a small ball peen hammer and lightly tap out the cardboard while holding it to the housing. This gives you the perfect outline to trim by.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078299
04/17/19 10:12 PM
04/17/19 10:12 PM
The Motor City
Global Moderator
Global Moderator
The Motor City
It's rather easy. Trace the thermostat housing on gasket material and cut. Gasket material doesn't have to be anything fancy. You can use thick paper material sometimes used in packaging or even milk carton material.
Beats running down to the store and paying 50 cents.
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078354
04/17/19 11:35 PM
04/17/19 11:35 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
You could use the cardboard box to make the gasket, and then keep some Indian Head shellac on hand to waterproof the paper before using it as a gasket.
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078360
04/17/19 11:58 PM
04/17/19 11:58 PM
Snagglefoot Offline
Snagglefoot  Offline
The OP was asking if red RTV gasket maker can be used as a gasket on a thermostat housing. Yes it can. smile
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078385
04/18/19 01:47 AM
04/18/19 01:47 AM
California
nthach Offline
nthach  Offline
California
It'll work - as long as the silicone is still dispensable and it "kicks". No Dex-Cool or "all makes all models" coolant of course...
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078407
04/18/19 03:31 AM
04/18/19 03:31 AM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
I did make a gasket for an integrated thermostat housing (plastic so) bolting on aluminium engine. Using red silicone. I tightened right after applying and filled the circuit 2 hours later and went for a drive. It's been 7 months and 7000 miles and no leak so far!
‘01 Peugeot Partner 1.9 D, 5W40 A3/B4, 258000 Km, running on WVO
Wife's ‘01 Toyota RAV4 3-dr 2.0 VVTi, 5W40 A3/B4, 148000 Km
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078408
04/18/19 03:32 AM
04/18/19 03:32 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
My BIL(48 yr diesel tech) always said that...you can't buy a gasket as good as what you can make with RTV.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: PotatoFarmer77w] #5078419
04/18/19 04:05 AM
04/18/19 04:05 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
For a small cost, I would do it right and get a gasket.
The "thinking" man's friend.
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: Lubener] #5078425
04/18/19 04:36 AM
04/18/19 04:36 AM
NY
demarpaint Offline
demarpaint  Offline
NY
If a gasket is available I'd buy one and use it, if not I'd make one. The RTV gasket maker I'd use a last resort. Opinions vary.
God Bless Our Troops
Re: Using red RTV gasket maker instead of a real gasket when replacing thermostat? [Re: Kestas] #5078433
04/18/19 05:10 AM
04/18/19 05:10 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
What material do you use?
And yes, you bring a really good point.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980 (Ecore)
Page 1 of 3 1 2 3
