Orbital Buffer - Boat Detailing
by PontiacHO - 01/24/20 10:32 AM
Do bolt threads grab at the same spot every time?
by motor_oil_madman - 01/24/20 10:26 AM
Amazoom Valvoline 5w30 deal
by volk06 - 01/24/20 09:28 AM
Forscan for Windows
by Donald - 01/24/20 07:30 AM
Group IV/V confirmed gear oils?
by metroplex - 01/24/20 06:34 AM
SATA Tools
by demarpaint - 01/24/20 05:10 AM
C-130
by Exhaustgases - 01/24/20 01:29 AM
Anyone Here Have a 9-Shot Rough Rider?
by ZeeOSix - 01/24/20 12:43 AM
Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Chevron Delo XLE 15W-40 CK4 (semi synthetic)
by HDoilDude - 01/23/20 08:45 PM
Coronavirus
by buster - 01/23/20 08:04 PM
Used vehicle shopping
by 53' Stude - 01/23/20 08:01 PM
Carquest oil and filter deal.
by JTK - 01/23/20 07:35 PM
Anti seize vs silicone paste
by buck91 - 01/23/20 06:57 PM
UOA - 11 VW GTI 2.0T TSI - Purol 10w40 - 5k
by dubman - 01/23/20 06:33 PM
Old SG/CD Mopar Vintage oil useless?
by BBDartCA - 01/23/20 06:32 PM
Great Slave Lake
by 53' Stude - 01/23/20 04:57 PM
Went used car shopping today. So interesting
by WhyMe - 01/23/20 04:33 PM
Connie7, 2020XT, 4strokes, Perseus, AJEwing
70517 Registered Users
85 registered members (A_Harman, Astro_Guy, AndyB, amblerman, 53' Stude, ArrestMeRedZ, 5 invisible), 2,106 guests, and 16 spiders.
Topics300,489
Posts5,177,124
Members70,514
bubbling paint/rust repair #5078129 04/17/19 06:32 PM
G
greenjp Offline OP
G
Looking for some advice on how to address the issue seen in these photos of my 2006 Accord. [Linked Image]
[Linked Image]
I am not terribly concerned about getting a "factory" or even close appearance, I just want to get rid of the bubbling paint and rust and use whatever combination/sequence of products necessary to prevent it from getting worse. I assume it'll start with chipping away the bubbles, then a sanding process of some sort, a rust converter or specialized primer, spray on touch up paint, and maybe a spray on clear coat? Any step by step advice or links to good how to's would be appreciated.
jeff
Re: bubbling paint/rust repair [Re: greenjp] #5078138 04/17/19 06:41 PM
A
alcyon Offline
A
Sand away the rust until you see bare metal or almost bare metal. Then wipe it down with a wet cloth to get all the loose particles off. Then wipe dry. Use Hammerite Kurust, apply with a brush . Let the Kurust cure, it will turn dark blue.
Once cured, you can spray your primer,or paint straight away. Dont forget to oil the inside part of the hood especially right under the rust if its possible.
Kyosho Optima Mid SWB, LWB and Lazer ZX
1991 Proton Saga 1.3S SOLD
1989 Toyota Soarer GT Twin Turbo L
1985 Kuwahara Survivor
1992 Robinson Pro
Re: bubbling paint/rust repair [Re: greenjp] #5078149 04/17/19 06:54 PM
spasm3 Offline
Be prepared that the repair area could end up at least twice as large as what you see, and as you sand it, it could end up being a rust through hole.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: bubbling paint/rust repair [Re: greenjp] #5078177 04/17/19 07:17 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
A sandblaster does a superior job of prepping the surface. It's a tool I bought when I started restoring cars.
Whatever you do, the rust will be back after 2-3 years unless the car is retired from salt duty.
Re: bubbling paint/rust repair [Re: greenjp] #5078185 04/17/19 07:23 PM
E
eljefino Offline
E
You're going to have a dickens of a time blending the paint on that very visible curve. Any new paint is going to get blasted by the slipstream-- it should be at least as durable as stock.
What's a perfect hood, $50 at the junkyard?
It may be worth doing nothing, so it won't look stupid to have done something $10 and then to have had it come out poorly.
Maybe you could fix it with a NAPA color matched spray-bomb then cover the mess with that 3M clear film. It'll disguise the color gradients and protect what's left.
Re: bubbling paint/rust repair [Re: greenjp] #5078206 04/17/19 07:42 PM
daves87rs Offline
Well, if it’s starting to rust there, I can imagine what the inside of the rest of that Accord is like. Wife’s Cavalier has rust like that on the hood....and no matter how hard I tried to save it- it will hit the junkyard soon.....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: bubbling paint/rust repair [Re: greenjp] #5078221 04/17/19 07:55 PM
2
2010Civic Offline
2
See if you can find a used hood in the same color. Much easier than trying to fix that. Check out car-part.com
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: bubbling paint/rust repair [Re: greenjp] #5078223 04/17/19 07:56 PM
R
Rolla07 Offline
R
Sand down to metal, isopropyl wipe let dry, prime, and touch up paint with 2 coats. Wax a month or two later. Thats what id do..and maybe a clear coat.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: bubbling paint/rust repair [Re: eljefino] #5078259 04/17/19 08:30 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I was going to say similar. Used hood.
Im not sure a repair will last. I suppose it could if done right, ground down to bare metal, etc.
If I had to repair it, Id grind it down, chemically convert the surface, and then take to maaco to color match...
Re: bubbling paint/rust repair [Re: greenjp] #5078350 04/17/19 10:29 PM
J
joegreen Offline
J
I almost guarantee you have a hole there once you pick away at it. If you want the rust gone you have to get it back to good steel.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: bubbling paint/rust repair [Re: greenjp] #5078444 04/18/19 04:54 AM
M
MasterSolenoid Offline
M
The rust most likely started under the hood where the seam is.
I would:
1) Scrap away the rust and see what you have
2) Open the hood and remove any rust
3) If you have a 'hole', rivet a patch on or use Body Filler.
This is why people Oil Undercoat their vehicles.
I suggest you buy an 'aerasol' can of Fluid Film and spray ALL the (inside) seams of Hood, Trunk and Doors
Doing so will prevent any future rust in those areas.
Spraying under vehicle
https://www.youtube.com/watch?v=L2bqMK2qT9Y
Atomizer Hose for 'inside' Doors and Hoods
https://www.youtube.com/watch?v=VmlM-jH5XBs
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: bubbling paint/rust repair [Re: greenjp] #5078447 04/18/19 04:56 AM
T
Trav Offline
T
There is a quite possibly a hole lurking under that. The right way with welding a patch and all the rest of it is time consuming and costly but there is a hack way that works surprisingly well and will hold for quite a while.
Mask the area off and grind it down then probe it with a screwdriver to see if it goes through, if it goes through grind it so rust is showing and wire wheel the back if possible.
Fill the hole with JB weld stick epoxy flattening it out behind and on top. Sand it smooth, touch up with bondo then use a self etching primer and then a regular primer filler and wet sand it smooth.
Paint the repair.
Do not use bondo fill the hole instead of JB weld, bondo is made with talc and absorbs water from behind causing moisture to get under the paint and bubble.
If you need more info or help PM me.
Edit: Make sure the drain holes on the inside of the hood at the front/sides are open.
Re: bubbling paint/rust repair [Re: greenjp] #5078454 04/18/19 05:09 AM
dlundblad Offline
I'd be concerned with rust being under the folded seam on the bottom of the hood too.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: bubbling paint/rust repair [Re: greenjp] #5078466 04/18/19 05:25 AM
Donald Online Content
Online Content
Its going to be a bigger deal and more work than you are thinking.
You could scrape away the major rust with a screwdriver and use one of the rust treatment products. They chemically change the rust. It will be better but by no means perfect. But its a 14 yr old vehicle. What the undercarriage look like? (rust wise)..
2015 Ford F-250 w/Powerstroke
Re: bubbling paint/rust repair [Re: Trav] #5078518 04/18/19 06:45 AM
doitmyself Offline
I learned about the Bondo absorbing water the hard way when I was a teenager (dinosaurs roamed the earth).
Even though the internet gurus frown on it for "proper" repairs, I have found that a fiberglass repair kit works very well when there is a hole on the backside. It is used for boats and is 100% water proof and the combo of fabric and resin gives it some strength.
