Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
OE AC COMPRESSOR?
by FA_WRX. 05/23/19 09:08 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
134 registered members (2003f7, 28oz, 53' Stude, 2strokeNorthstar, 19 invisible), 2,234 guests, and 24 spiders.
Topics289,300
Posts4,966,493
Members68,181
Most Online2,967
Mar 10th, 2019
Ford 3.0L transmission problem #5078187
04/17/19 08:24 PM
04/17/19 08:24 PM
North Carolina, USA
taztheman Offline OP
North Carolina, USA
If anyone has any helpful advice it would be greatly appreciated. I have a 2000 Ford Ranger and whenever the engine/transmission gets hot (after a long drive) the transmission will shift harshly. It has very harsh shifts from 1-2. But whenever the transmission is cold it works perfectly fine. I don't have a check engine light on and the transmission fluid is clean and doesn't smell burnt. I am planning on changing the transmission fluid, filter, and valve body gasket.
Thanks
Re: Ford 3.0L transmission problem [Re: taztheman] #5078201
04/17/19 08:39 PM
04/17/19 08:39 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Any idea of maintenance history? If not, then filter and fluid to start, maybe go ahead and do the valve body gasket.
I've "fixed" a couple with just fluid and filter. Never done the valve body fix personally, never needed to.
These transmissions need regular fluid replacement, and ideally need it done early on. They last a long time if they get a fluid change early. Filter doesn't matter as much unless fluid is neglected.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 229K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 201K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 248K miles
Re: Ford 3.0L transmission problem [Re: taztheman] #5078224
04/17/19 08:58 PM
04/17/19 08:58 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
What mileage? I think your plan is a great starting point. Go from there
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Ford 3.0L transmission problem [Re: taztheman] #5078226
04/17/19 09:00 PM
04/17/19 09:00 PM
KS
FordBroncoVWJeta Online content
FordBroncoVWJeta  Online Content
KS
I'd add a quart of Lucus Transmission fix. That stuff did wonders for a couple of the transmissions in my cars with hard shifts.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Ford 3.0L transmission problem [Re: taztheman] #5078230
04/17/19 09:02 PM
04/17/19 09:02 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I don’t know anything about transmissions but I had an automatic escort that would do the same thing. Regular fluid changes with Castrol Import Multi vehicle would lessen the hard shifting when hot. Castrol imv is merconV rated but is a little thicker than other merconV fluids.
Re: Ford 3.0L transmission problem [Re: FordBroncoVWJeta] #5078239
04/17/19 09:12 PM
04/17/19 09:12 PM
Birmingham, AL
01rangerxl Offline
01rangerxl  Offline
Birmingham, AL
Not yet, maybe as an absolute last resort.
Re: Ford 3.0L transmission problem [Re: taztheman] #5078255
04/17/19 09:28 PM
04/17/19 09:28 PM
Texas, USA
PPWarrior Offline
PPWarrior  Offline
Texas, USA
Have you changed your coolant?
Re: Ford 3.0L transmission problem [Re: taztheman] #5078272
04/17/19 09:40 PM
04/17/19 09:40 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
I would scan it for codes regardless!!
The PCM controls line pressure based on "Calculated Load"......MAF & TPS are the main inputs for this calculation.
Line pressure testing with a pressure gauge is invaluable & sometimes absolutely necessary to diagnose a automatic transmissions. When/If you want/need to do this.....I have a lot of information.
4R44E & 5R55E units require TWO gauges & whips, One for Main Line Pressure & the other for Pressure Control Solenoid Pressure.
2001 Chevy Camaro L92/4L80E
Re: Ford 3.0L transmission problem [Re: taztheman] #5078348
04/17/19 11:23 PM
04/17/19 11:23 PM
Boulder, Colorado
boulderdentist Offline
Boulder, Colorado
I had an 1989 Ranger which I purchased from my Dad in 2002, was his new in 1989. I just did drop pan, change filter every 30,000 miles or so and the original transmission went to 269,000 before failing. I had it rebuilt and finally gave up on the vehicle at 336,000 miles, transmission still doing fine, too many other problems. Original engine when scrapped. Suspension worn out, front and back windows leaking during rains, rear main seal leak, etc. I would start with fluid and filter. Then if problems some transmission shops will do no cost diagnosis. How many miles on the transmission?
Scott
Re: Ford 3.0L transmission problem [Re: taztheman] #5078410
04/18/19 03:38 AM
04/18/19 03:38 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
Need more information.
Start with the basics.
How long have you owned this Ranger?
Is this harsh shift just starting?
Do you know the history?
Check level and if you have to add, just change ATF & filter. It may just need new fluid.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
