Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Motorcraft Mercon V opinions?
by Vigilant. 06/25/19 05:28 PM
New Personal Best MPG
by Kjmack. 06/25/19 05:01 PM
DuraMAX Synthetic Oil?
by Torino117. 06/25/19 04:54 PM
Battery Cables!
by NYEngineer. 06/25/19 04:35 PM
Brake Rotors
by WyrTwister. 06/25/19 04:00 PM
Rubber cement tubes?
by buck91. 06/25/19 03:53 PM
2019 Camaro SS 10sp auto, brief review
by Cujet. 06/25/19 03:14 PM
John Deere LX280 Help!
by johnmichael. 06/25/19 03:01 PM
Which grease?
by maverickfhs. 06/25/19 12:43 PM
Potenza SO4 Pole Position on the 968
by BeerCan. 06/25/19 12:15 PM
New wheels and tires on our VW Passat
by SLO_Town. 06/25/19 11:28 AM
Absorber drying chamois
by Redright9. 06/25/19 10:36 AM
Mobil Delvac Rebate
by GMguy84. 06/25/19 10:29 AM
Sister wants an Audi q5
by 1978elcamino. 06/25/19 10:21 AM
Annual Father/Son Varmint Hunting Trip
by 2015_PSD. 06/25/19 09:53 AM
2019 Subaru Impreza anyone?
by sw99. 06/25/19 09:46 AM
Torino117, Blue_moon, jim_russ, johnmichael, TIMPEHL
68483 Registered Users
96 registered members (2015_PSD, alchargo, 53' Stude, AC1DD, AdditiveOCD, AandPDan, 8 invisible), 2,247 guests, and 30 spiders.
Topics290,962
Posts4,995,973
Members68,483
Most Online2,967
Mar 10th, 2019
bubbling paint/rust repair #5078129
04/17/19 07:32 PM
04/17/19 07:32 PM
Germantown, MD
greenjp Offline OP
greenjp  Offline OP
Germantown, MD
Looking for some advice on how to address the issue seen in these photos of my 2006 Accord. [Linked Image]
[Linked Image]
I am not terribly concerned about getting a "factory" or even close appearance, I just want to get rid of the bubbling paint and rust and use whatever combination/sequence of products necessary to prevent it from getting worse. I assume it'll start with chipping away the bubbles, then a sanding process of some sort, a rust converter or specialized primer, spray on touch up paint, and maybe a spray on clear coat? Any step by step advice or links to good how to's would be appreciated.
jeff
Re: bubbling paint/rust repair [Re: greenjp] #5078138
04/17/19 07:41 PM
04/17/19 07:41 PM
Kuala Lumpur ,Malaysia
alcyon Offline
alcyon  Offline
Sand away the rust until you see bare metal or almost bare metal. Then wipe it down with a wet cloth to get all the loose particles off. Then wipe dry. Use Hammerite Kurust, apply with a brush . Let the Kurust cure, it will turn dark blue.
Once cured, you can spray your primer,or paint straight away. Dont forget to oil the inside part of the hood especially right under the rust if its possible.
Kyosho Optima Mid SWB, LWB and Lazer ZX
1991 Proton Saga 1.3S SOLD
1989 Toyota Soarer GT Twin Turbo L
1985 Kuwahara Survivor
1992 Robinson Pro
Re: bubbling paint/rust repair [Re: greenjp] #5078149
04/17/19 07:54 PM
04/17/19 07:54 PM
out there
spasm3 Online content
spasm3  Online Content
out there
Be prepared that the repair area could end up at least twice as large as what you see, and as you sand it, it could end up being a rust through hole.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: bubbling paint/rust repair [Re: greenjp] #5078177
04/17/19 08:17 PM
04/17/19 08:17 PM
The Motor City
Kestas Online content
Global Moderator
Kestas  Online Content
Global Moderator
The Motor City
A sandblaster does a superior job of prepping the surface. It's a tool I bought when I started restoring cars.
Whatever you do, the rust will be back after 2-3 years unless the car is retired from salt duty.
Re: bubbling paint/rust repair [Re: greenjp] #5078185
04/17/19 08:23 PM
04/17/19 08:23 PM
ME
eljefino Online content
eljefino  Online Content
ME
You're going to have a dickens of a time blending the paint on that very visible curve. Any new paint is going to get blasted by the slipstream-- it should be at least as durable as stock.
What's a perfect hood, $50 at the junkyard?
It may be worth doing nothing, so it won't look stupid to have done something $10 and then to have had it come out poorly.
Maybe you could fix it with a NAPA color matched spray-bomb then cover the mess with that 3M clear film. It'll disguise the color gradients and protect what's left.
Re: bubbling paint/rust repair [Re: greenjp] #5078206
04/17/19 08:42 PM
04/17/19 08:42 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Well, if it’s starting to rust there, I can imagine what the inside of the rest of that Accord is like. Wife’s Cavalier has rust like that on the hood....and no matter how hard I tried to save it- it will hit the junkyard soon.....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: bubbling paint/rust repair [Re: greenjp] #5078221
04/17/19 08:55 PM
04/17/19 08:55 PM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
See if you can find a used hood in the same color. Much easier than trying to fix that. Check out car-part.com
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: bubbling paint/rust repair [Re: greenjp] #5078223
04/17/19 08:56 PM
04/17/19 08:56 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Sand down to metal, isopropyl wipe let dry, prime, and touch up paint with 2 coats. Wax a month or two later. Thats what id do..and maybe a clear coat.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: bubbling paint/rust repair [Re: eljefino] #5078259
04/17/19 09:30 PM
04/17/19 09:30 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
I was going to say similar. Used hood.
Im not sure a repair will last. I suppose it could if done right, ground down to bare metal, etc.
If I had to repair it, Id grind it down, chemically convert the surface, and then take to maaco to color match...
Re: bubbling paint/rust repair [Re: greenjp] #5078350
04/17/19 11:29 PM
04/17/19 11:29 PM
NY
joegreen Offline
joegreen  Offline
NY
I almost guarantee you have a hole there once you pick away at it. If you want the rust gone you have to get it back to good steel.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: bubbling paint/rust repair [Re: greenjp] #5078444
04/18/19 05:54 AM
04/18/19 05:54 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
The rust most likely started under the hood where the seam is.
I would:
1) Scrap away the rust and see what you have
2) Open the hood and remove any rust
3) If you have a 'hole', rivet a patch on or use Body Filler.
This is why people Oil Undercoat their vehicles.
I suggest you buy an 'aerasol' can of Fluid Film and spray ALL the (inside) seams of Hood, Trunk and Doors
Doing so will prevent any future rust in those areas.
Spraying under vehicle
https://www.youtube.com/watch?v=L2bqMK2qT9Y
Atomizer Hose for 'inside' Doors and Hoods
https://www.youtube.com/watch?v=VmlM-jH5XBs
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: bubbling paint/rust repair [Re: greenjp] #5078447
04/18/19 05:56 AM
04/18/19 05:56 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
There is a quite possibly a hole lurking under that. The right way with welding a patch and all the rest of it is time consuming and costly but there is a hack way that works surprisingly well and will hold for quite a while.
Mask the area off and grind it down then probe it with a screwdriver to see if it goes through, if it goes through grind it so rust is showing and wire wheel the back if possible.
Fill the hole with JB weld stick epoxy flattening it out behind and on top. Sand it smooth, touch up with bondo then use a self etching primer and then a regular primer filler and wet sand it smooth.
Paint the repair.
Do not use bondo fill the hole instead of JB weld, bondo is made with talc and absorbs water from behind causing moisture to get under the paint and bubble.
If you need more info or help PM me.
Edit: Make sure the drain holes on the inside of the hood at the front/sides are open.
Re: bubbling paint/rust repair [Re: greenjp] #5078454
04/18/19 06:09 AM
04/18/19 06:09 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I'd be concerned with rust being under the folded seam on the bottom of the hood too.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980 (Ecore)
Re: bubbling paint/rust repair [Re: greenjp] #5078466
04/18/19 06:25 AM
04/18/19 06:25 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Its going to be a bigger deal and more work than you are thinking.
You could scrape away the major rust with a screwdriver and use one of the rust treatment products. They chemically change the rust. It will be better but by no means perfect. But its a 14 yr old vehicle. What the undercarriage look like? (rust wise)..
2015 Ford F250 w/Powerstroke
Re: bubbling paint/rust repair [Re: Trav] #5078518
04/18/19 07:45 AM
04/18/19 07:45 AM
MI
doitmyself Offline
doitmyself  Offline
MI
I learned about the Bondo absorbing water the hard way when I was a teenager (dinosaurs roamed the earth).
Even though the internet gurus frown on it for "proper" repairs, I have found that a fiberglass repair kit works very well when there is a hole on the backside. It is used for boats and is 100% water proof and the combo of fabric and resin gives it some strength.
