Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
128 registered members (addyguy, 2015_PSD, 2012AccentSE, 28oz, 53' Stude, Ag76, 11 invisible), 2,150 guests, and 28 spiders.
Topics289,301
Posts4,966,573
Members68,181
Most Online2,967
Mar 10th, 2019
2016 ford fusion lug nut size and torque spec? #5078126
04/17/19 07:32 PM
04/17/19 07:32 PM
Pullman Wa.
Corollaman Offline OP
Pullman Wa.
Are the lug nuts 19mm and torque spec 100 ft lbs? Tried researching on the internet that's what I found.
Re: 2016 ford fusion lug nut size and torque spec? [Re: Corollaman] #5078143
04/17/19 07:46 PM
04/17/19 07:46 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
2004 Corolla 131893
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74840
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2016 ford fusion lug nut size and torque spec? [Re: Corollaman] #5078147
04/17/19 07:52 PM
04/17/19 07:52 PM
New England
gathermewool Online content
gathermewool  Online Content
New England
Did you lose your owner's manual?
Did you even Google???
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Magnatec 5W-20 + FU filter (47,300 miles)
Re: 2016 ford fusion lug nut size and torque spec? [Re: Corollaman] #5078153
04/17/19 07:56 PM
04/17/19 07:56 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
I googled 2016 Ford Fusion owners manual pdf
and this was the 1st result:
http://www.fordservicecontent.com/F...rs-Manual-version-1_om_EN-US_03_2015.pdf
Page 314 tells you the torque.
For the socket size, get out your sockets and check.
Second google, ford m12x1.5 socket size
2nd result says 19mm
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: 2016 ford fusion lug nut size and torque spec? [Re: UG_Passat] #5078173
04/17/19 08:14 PM
04/17/19 08:14 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
m12x1.5 is the thread size /pitch
19mm is the head size (socket size)
Re: 2016 ford fusion lug nut size and torque spec? [Re: Corollaman] #5078180
04/17/19 08:19 PM
04/17/19 08:19 PM
ME
eljefino Online content
eljefino  Online Content
ME
If you ever get confused again go to rock auto and look for a lug nut or a wheel stud. They'll give specs.
Most lugs are either 12mm or 1/2", you can put an open end wrench over and it'll "Just fit". For the thread pitch, lay the wrench on its side-- 1.5mm pitch means 8 threads visible across your 12mm open end.
Re: 2016 ford fusion lug nut size and torque spec? [Re: Corollaman] #5078267
04/17/19 09:36 PM
04/17/19 09:36 PM
Ohio
hallstevenson Offline
Ohio
The lug nuts hex head is 19mm (meaning you use a 19mm socket to get them off) and yes, 100 ft/lbs for the torque spec.
