Forgotten baby syndrome
by doitmyself. 05/23/19 02:53 PM
Missouri Tornado
by kstanf150. 05/23/19 02:28 PM
Monroe Econo-matics on '07 RAV4 - horrible
by MoreCowbellAz. 05/23/19 01:48 PM
2019 Crosstrek
by Al. 05/23/19 01:47 PM
Sam's club tire sale
by zmelli. 05/23/19 01:27 PM
Craftsman floor jack rebuild
by i6pwr. 05/23/19 01:14 PM
Napa 1334 Now made in South Korea
by Valkyrie_Rider. 05/23/19 12:22 PM
2004 Prius - Repair or Sell?
by The Critic. 05/23/19 11:57 AM
Get mechanic to check out used car?
by AuthorEditor. 05/23/19 11:24 AM
OK to use this PSF on Hondas too?
by GSCJR. 05/23/19 10:53 AM
Grease for Toyota Tundra
by diyjake. 05/23/19 10:09 AM
Made in USA?
by buck91. 05/23/19 10:00 AM
Email address for Mobil e check?
by BTLew81. 05/23/19 09:29 AM
OE AC COMPRESSOR?
by FA_WRX. 05/23/19 09:08 AM
Up2nogood, JP69, Bluethunder, patcatpat, Wilvoeka
68181 Registered Users
131 registered members (2003f7, 28oz, 53' Stude, 2strokeNorthstar, 18 invisible), 2,225 guests, and 25 spiders.
Topics289,300
Posts4,966,493
Members68,181
Most Online2,967
Mar 10th, 2019
Kohler Command Twin 18HP - not charging #5078059
04/17/19 06:26 PM
04/17/19 06:26 PM
Flaherty, KY
92saturnsl2 Offline OP
Flaherty, KY
I have two lawn tractors, both have Kohler Command Twins, one a 23 horse, the other is a 18.
The 23 horse unit charges fine. Voltage while running hovers right at 14.0V, when I shut the mower down the battery is usually around 12.8V (maybe a bit higher until the surface charge wears off).
On the 18 horse, it either isn't charging or not charging well. I can't recall the battery being drained completely (I usually hook the charger to it occasionally to prevent that), but it does not behave like the other mower. Voltage while running is usually 12.75 volts or so, and when I shut the mower down battery settles in at 12.5. If I hook a charger to it, the battery will accept plenty more charge, so evidently it's not being charged fully. This particular mower has an ammeter, and when the PTO is engaged or headlights on, the needle reads in the negative (discharge) side of the gauge. If both PTO and lights are on, it's substantially in the negative side. If the mower is just idling at high RPM, the gauge will rest just a hair into the positive.
Just for grins, I swapped what looks like a bridge rectifier (mounted on side of block and has three prongs: AC, AC and B+) between the two mowers. No change.
Any ideas how to go about diagnosing this?
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40
04 Odyssey EX 190k Valv. Durablend 5w-30
96 Maxima GLE 265k Chevron Delo LE 5w-40
07 Chrysler Pacifica Limited 4.0L 140k Belgian Castrol Edge 0w-30 Euro
Re: Kohler Command Twin 18HP - not charging [Re: 92saturnsl2] #5078084
04/17/19 06:53 PM
04/17/19 06:53 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
How old is the battery on the 18hp?
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Kohler Command Twin 18HP - not charging [Re: 92saturnsl2] #5078133
04/17/19 07:36 PM
04/17/19 07:36 PM
USA
mk378 Offline
mk378  Offline
USA
Make sure the rectifier/regulator is grounded (zero volts from the case to battery (-) when running)
The B+ wire should have battery voltage. The two AC wires should have close to zero ohms resistance to each other through the alternator coil, and an AC voltage of about 15-20 volts when running. Unplugged there should be no continuity from the AC wires to ground.
Re: Kohler Command Twin 18HP - not charging [Re: JTK] #5078229
04/17/19 09:01 PM
04/17/19 09:01 PM
Flaherty, KY
Flaherty, KY
Battery is only a year or so old-- I've swapped it out with another to no effect.
Re: Kohler Command Twin 18HP - not charging [Re: 92saturnsl2] #5079273
04/18/19 08:44 PM
04/18/19 08:44 PM
ms
racinjason Offline
racinjason  Offline
ms
Doubt it’s the regulator. As everyone said, check for ground at the regulator and 12v at center regulator terminal.
My money is on the magnets have fallen off the flywheel.
One way to check is read the ac voltage on the two stator wires(outside wires on regulator) running full rpm unplugged, should be 28 or more.
Re: Kohler Command Twin 18HP - not charging [Re: 92saturnsl2] #5079590
04/19/19 08:18 AM
04/19/19 08:18 AM
Jupiter, Florida
Cujet Online content
Cujet  Online Content
Jupiter, Florida
Many of those regulators are "total loss". In other words, the alternators produce what they can at any given RPM, the regulator rectifies the AC into DC, and shunts to ground, any excess power, maintaining 13.8V on the system.
It's easy enough to measure the coils on the alternator for conductivity and short to ground. It's not so easy to test a regulator. Replacement of the regulator is generally cheap enough to be worth trying.
