Forums Migration
Please read this thread
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
Carburetors - I think I've learned to like them
by Kurtatron - 07/06/20 09:40 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
87 registered members (4WD, 86cutlass307, aba4430, ABN_CBT_ENGR, 77GrandPrix, 2015_PSD, 6 invisible), 1,604 guests, and 31 spiders.
Topics307,541
Posts5,312,722
Members71,870
Recommendation on API "SJ" oil source #5076815 04/16/19 02:16 PM
L
LPE Offline OP
L
Can anyone recommend a currently available brand of oil that is API "SJ" in quart containers in HD30, 10W30 and 5W30? I prefer to stay away from the current "SN" and "SN+" oils that are currently offered for my small engines. Am I all wrong here looking for this blend? I don't care if it's conventional or synthetic. Thanks.
Re: Recommendation on API "SJ" oil source [Re: LPE] #5076823 04/16/19 02:26 PM
blupupher Offline
Nobody makes an SJ oil as far as I can see.
Sounds like you are wanting a HDEO.
'18 Santa Fe: PP 10w-30/OEM
'18 Soul: Delo 400 10w-30/ST
'12 xB: M1 EP 0w-20/CQ Blue
'10 Santa Fe: Pento HP 5W-30/TG
'04 F150: Delo 400 10w-30/ST
'02 F150: PP 0w-20/M1
'94 GL1500: Honda 10w-40/OEM
Re: Recommendation on API "SJ" oil source [Re: LPE] #5076833 04/16/19 02:34 PM
skyactiv Offline
Why do you think your equipment will be better served by using an SJ oil?
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Recommendation on API "SJ" oil source [Re: skyactiv] #5076848 04/16/19 02:47 PM
L
LPE Offline OP
L
Briggs and Stratton recommends this for their small engines. A few years ago a new eight HP B&S came with "SN" oil. I didn't like the look of the oil at five hours when I changed the oil. Ran it 20 hours and still didn't like the look of the oil so I sent it out to Blackstone for analysis. It had a lot of aluminum and iron so they recommended changing it sooner. Ran SJ this change and it looked better at 20 hours and tested much better.
Re: Recommendation on API "SJ" oil source [Re: LPE] #5076865 04/16/19 03:04 PM
L
LPE Offline OP
L
I may be stuck with Briggs and Stratton branded oil but they only offer it in 20 oz and 48 oz. bottles. I still find it at farm stores. I also found some Honda branded 10W30 oil at the local marine dealership.
Re: Recommendation on API "SJ" oil source [Re: LPE] #5076868 04/16/19 03:05 PM
B
Boomer Offline
B
Rotella straight 30W was SJ rated just a few years ago. I don't think anyone uses that designation anymore as it outdated and API won't allow its use.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Recommendation on API "SJ" oil source [Re: LPE] #5076891 04/16/19 03:33 PM
L
LPE Offline OP
L
Thank you Boomer.
Re: Recommendation on API "SJ" oil source [Re: LPE] #5076902 04/16/19 03:38 PM
skyactiv Offline
Honda 10W30 motorcycle oils are SJ rated. They are found at Honda motorcycle dealers.
If I read it correctly somewhere, it is not a thin 10W30. Honda supposedly did testing using thinner oils in motorcycles
and found it wears out the transmission faster.
http://prohondaoil.com/engine-oils/4-stroke-engines/
Re: Recommendation on API "SJ" oil source [Re: LPE] #5077077 04/16/19 06:51 PM
A
Audios Offline
A
BMWs 5/30 is still SL rated, thats about the closest Ive seen.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Recommendation on API "SJ" oil source [Re: LPE] #5077086 04/16/19 07:01 PM
N
NH73 Offline
N
Is this typical of new small gas engines? It usually seems the first oil always come out gray. I don't believe that is the result of using SN or SN+ oils. That is manufacturing junk that should clear up by now. If the engine is used a little bit around the house, any 5w30 full synthetic or 10w30 will do. If your running it day in and day out, I would use a HDEO 15w40, or 15w50.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Recommendation on API "SJ" oil source [Re: LPE] #5077106 04/16/19 07:21 PM
M
Merek Offline
M
Kohler makes a good small engine oil and has lots of zinc. I currently have Rotella t5 10w30 in my Briggs opposed twin but have used Delo LE 5w40, and Pennzoil sae 30 too. That's the problem even with sae 30 is that they get upgraded as well so most of the ones you are going to find on the shelf today are going to be SN rated.
The motorcycle oils's are not SN rated at least none of the ones I've noticed, they've all been prior to SM being rated as SG/SH/SJ.
Re: Recommendation on API "SJ" oil source [Re: NH73] #5077115 04/16/19 07:26 PM
M
Merek Offline
M
Yes anytime with a new small engine or really any engine you will get some silver like that in the oil but after a few changes it will go away. I bought a new small 30 gallon single stage air compressor that's belt driven and it did the same thing. It's nothing to worry about and it leeches out of the metal until it stops, both my Honda gcv160 and our new Husq. awd push mower w/ Briggs did this when changing the oil.
Re: Recommendation on API "SJ" oil source [Re: LPE] #5077137 04/16/19 07:44 PM
B
bubbatime Offline
B
Based on your climate, just run a heavy duty engine oil in 10W30.
Kohler, John Deere, Yamaha, Suzuki, Rotella, Delo, Delvac, Mercury Marine, Quicksilver marine, all suitable, all good oils, all come in 10W30. All are more robust than your standard passenger 10W30 SN.
Also, the first two oil changes typically on a new small engine is going to be filled with nasty aluminum flakes and glitter. This is across the industry, and not because you ran one engine oil over another. The cheapest SN oil 10W30 you can buy will serve your engine just fine and the engine will last almost forever in your climate with routine oil changes.
Re: Recommendation on API "SJ" oil source [Re: LPE] #5077179 04/16/19 08:23 PM
M
MParr Offline
M
Go to Walmart and get some Super Tech HD 30.
Printed On: March 19, 2019
Description
WALMART HD 30 6/1QT WSE
Inspection Information Test Method Typical Value
Gravity, °API
ASTM D287
29.85
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.877
Flash Point, °C
ASTM D92
210
Flash Point, °F ASTM D92 410
Viscosity @ 40°C, cSt
ASTM D445
87.96
Viscosity @ 100°C, cSt ASTM D445 10.94
Viscosity Index
ASTM D2270
110
Pour Point, °C (°F) ASTM D5950 -33°C (-27°F)
High Temperature / High Shear Vis at 150°C, cP
ASTM D5481
3.38
Noack Volatility, % loss ASTM D6375 6.1
Color
ASTM D1500
3
Zinc, wt. % ASTM D5185 0.085
Phosphorus, wt. %
ASTM D5185
0.077
Calcium, wt. % ASTM D5185 0.132
Sulfur, wt. %
ASTM D4951
0.3
Magnesium, wt. % ASTM D5185 0.043
Boron, wt. %
ASTM D5185
0.018
Molybdenum, wt. % ASTM D5185 0.004
Sulfated Ash, wt. %
ASTM D874
0.92
Nitrogen, wt. % ASTM D4629 0.086
TBN, mgKOH/g
ASTM D2896
7
Claims Information
API SN PLUS
Approved
API SN Approved
API SM
Meets Requirements
API SL Meets Requirements
API SJ, SH, SG, SF, SE, SD, SC
Meets Requirements
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Recommendation on API "SJ" oil source [Re: LPE] #5077182 04/16/19 08:26 PM
slacktide_bitog Offline
A motorcycle oil? shrug
