Your iron is really the only thing here that looks a little out of whack at first glance... until you look at the universal averages. There, you will find that this engine seems to make right around 5ppm FE/1k miles, which means at ~12k you would be perfectly normal in the 60-62ppm Fe range. However, you are at 55ppm, which means your engine is shedding less, which is a good thing. Go to 14k, or get crazy and go to 15. There's no real worry with how low the rest of the wear metals are; iron becomes a concern over 150ppm, and viscosity and TBN are still great. That oil had plenty of life left at 12k.
