Tried doing my wife's rear brakes last weekend and could not get the calipers to compress, it is the type where you use a tool to turn the piston in to retract into the bore.
I have done a couple other GM cars with no problem but these just turn and turn but do not retract. The only thing I can think of is to maybe try to put more pressure on them while turning because it was awkward trying to do so with the caliper just sitting on top the bracket. It has the electronic parking brake but not solenoids at the wheel, just cables like our old Malibu.
How much pressure should it take to get them to go in? Maybe I will just get new calipers? I think there may be a tool that fits into the caliper support that turns and puts pressure at the same time?
