Originally Posted by atikovi
Originally Posted by gathermewool
What you SHOULD do, on a go-forward basis, is spend the $15 (or less) to get a multimeter. You can even buy a cheap lighter-socket plug-in that will display voltage. Why in the world would you guess that the alternator might not be up to snuff when you can spend seconds checking it???
I don't need any tool to tell me the alternator isn't charging. Most cars sold in the last 80 years have a gauge or battery light on the dash that illuminates when there is a charging problem.
Two years ago I was in a vehicle of a friend of mine on a trip for a weekend.After driving for 2 hours and stoping to idle rpms engine died and we had no electric power to start the engine.
The Battery was completely drained and it proved to be a faulty alternator that did not charge properly.
The light on the dash did not came up (not even flickering).
A multimeter is like a swiss knife , useful in many everyday situations and quite cheap,gives clues in seconds.Don't be negative on the matter.
