Hi,
Does anyone know which part is responsible for springing back a manual shift lever back to center neutral position?
For example when you go from any gear back into neutral and it automatically springs back to center.
It feels sticky side-to-side movement.
Is there a spring inside the gear selector (10 or 11) or is the problem more likely with the gear snifter linkage (13, 14, 15, 16, 18)?
