Originally Posted by Astro14
Originally Posted by supton
Tundra also--no start/stop, AFM, DI, etc. 6AT last I knew of too. It's main weakness is DOHC and while that's not a real problem, the cam tower sealing is (high leakage rate). Along with the typical Toyota problems (rust, water pumps, rust, steering racks, rust, front diff and rust). Sealed automatic too, and at some point they ditched the ATF cooler apparently (there's a recent thread on the topic).
I'll second the Tundra.
As late as 2016, it still had an oil cooler and a big transmission cooler. Simple, big V-8 (which sounds great when you get on it, by the way), port FI, conventional automatic. That simplicity is why I bought it over the competition. That simplicity also results in lousy gas mileage when compared with the competition.
The automatic isn't "sealed", but it's not super easy to service. A fill port is on the side, and you set the level using a plug that has a standing tube above it. Open the plug at a specified temperature range, be certain that the fluid is up to the standpipe level by observing the fluid drain. It was easier to do a cooler line flush on this (which requires pinning the oil cooler thermostat open) than on many cars I've owned.
No rust yet on mine, despite snow and salt water. But it got Fluid film when it was brand new, and AMSOIL MP every oil change.
Not one repair, yet, either.
Just fluids and filters.
Been meaning to tell you, make sure to hammer out the pins on the front brakes--they like to take a set from rust. I made the mistake of letting them sit for a couple of years, and they have to be hammered out. Luckily they clean up easily enough, but now I need to get a spare set.
