My 2013 Honda Fit Undercarriage after
by TDOHGL01 - 01/17/20 09:08 AM
Oil that won't clog the catalytic converter?
by Underdawg - 01/17/20 08:46 AM
Rear Struts Recommendations
by willbur - 01/17/20 07:46 AM
Critical Windows 10 Update
by doitmyself - 01/17/20 07:38 AM
Dry Gas in exteme cold weather
by FA_WRX - 01/17/20 06:57 AM
ATF VS ATL
by jrommelt - 01/16/20 11:24 PM
inline oiler for water separator on compressor
by motor_oil_madman - 01/16/20 10:55 PM
5w30 Throw Off VVT [ 5w20 Vehicle ] ?
by Fallguy - 01/16/20 10:54 PM
Ravenol MTF-2
by E365 - 01/16/20 10:36 PM
Road Rage, Then vs Now
by gathermewool - 01/16/20 09:39 PM
Interesting Taillight Out Code
by Gebo - 01/16/20 09:39 PM
Well its here again
by JohnnyJohnson - 01/16/20 06:56 PM
My cheap old stock oil score!
by CleverUserName - 01/16/20 06:52 PM
Trans runs better in severe cold...
by 2009Caraman - 01/16/20 06:41 PM
LSx rocker bolt sealant
by P10crew - 01/16/20 06:00 PM
Nissan Titan any good?
by dfarr67 - 01/16/20 05:24 PM
Cockford-Ollie
by 1978elcamino - 01/16/20 05:23 PM
ATI balancer keyway sealing
by P10crew - 01/16/20 04:53 PM
Silkolene (FUCHS) 10w-60 On Amazon
by BBDartCA - 01/16/20 04:19 PM
To use or not to use
by JHogan - 01/16/20 04:13 PM
MrGoodwrench, Schwifty, Karoofrans, Marksvc1, Anthony_Butcher
70452 Registered Users
105 registered members (1978elcamino, Aichiguy, alchargo, 77GrandPrix, 750IX, adams355, 6 invisible), 2,089 guests, and 22 spiders.
Topics300,221
Posts5,171,177
Members70,452
Most Online3,728
Jan 11th, 2020
Jiffy Lube And Oil Filters???? #5071755 04/11/19 02:27 PM
W
Willclark Offline OP
W
I have read that Jiffy Lube and other quick change places use "jobber" oil filers when you get the oil changed. I assume that this means they are cheap. But would they be, at least, equal to an Fram orange can in quality?
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071787 04/11/19 03:00 PM
R
RamFan Offline
R
I sense a troll but I'll bite.
A jobber filter is perfectly fine in most applications. Yes, they are usually made in China. And yes, they typically do not disclose an efficiency rating. But, and this is the big part, they're typically just as well built as a name brand filter. I was briefly in the industry and the only filters that consistently gave us problems where white label Champ filters. Never a notable issue with any others, in all honesty, one of my favorites brands was Security Global which are distributed through Service Champ. Rock solid construction and very cheap in bulk.
In fact, you can go to Rock Auto and buy the same jobber filters these lube shops use. Many on this site (myself included) do just that! Champ, Premium Guard, Ecogard, etc. are all available for purchase to you and they're no different than the ones used in shops.
To answer your question more directly, yes a jobber filter is at least equal to a Fram orange can in quality. Minus the silicone adbv.
18 Giulia Ti Sport Q4
  • 2.0T I4 - 22k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 67k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071798 04/11/19 03:19 PM
Y
y_p_w Offline
Y
Depend on where you go. The big American filter manufacturers (Fram, Wix, Champion Labs, Baldwin) pretty much all make some of these filters, although there might be more from overseas these days. It doesn't really cost all that much to make a filter. That $1.50 filter is at least equivalent to an orange can Fram.
I thought with the Pennzoil association they often use Pennzoil branded filters. It was years ago, but I remember seeing Pennzoil branded filters sold at a drug store. They had an extremely limited selection, but I saw that the application they recommended for my car actually had two different filters with the same part number. One had all the hallmarks of Fram while the other one looked like a Wix design.
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071808 04/11/19 03:33 PM
F
FordBroncoVWJeta Offline
F
Walmart uses Fram "Core" filters. Only difference between them and the extra gaurd Is the orange sandpaper grip. I've cut a couple open and couldn't tell a difference.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071813 04/11/19 03:41 PM
J
JustinH Online Content
Online Content
J
Just had my wifes scion in for a jiffy lube signature oil change.
I'll see what the part number is on the invoice.
I'd bet it is Pennzoil brand filters made for the chain, because all they pour is Pennzoil.
'16 Ford Escape
'11 Scion XB
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071820 04/11/19 03:46 PM
Donald Offline
Whatever oil and filter they provide is better then no oil change.
Unless something odd happens your car can run on cheap (but sped'ed) oil & filters all its life and the engine will still be running fine when it hits the boneyard.
2015 Ford F-250 w/Powerstroke
Re: Jiffy Lube And Oil Filters???? [Re: Donald] #5071826 04/11/19 03:53 PM
G
gfh77665 Offline
G
Assuming it really does get changed...
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071841 04/11/19 04:12 PM
W
W
I'm not trying to bash Jiffy Lube. I relied on them when I had sever back problems. I liked how they showed my the oil stick with fresh oil after they did it. The coffee was horrible though and the waiting room stunk bad though.
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071854 04/11/19 04:29 PM
B
Brigadier Offline
B
I stand outside and talk to the guys and watch them. Had some nice conversations......and they let me take my own oil and filter, no worries.
Re: Jiffy Lube And Oil Filters???? [Re: Donald] #5071864 04/11/19 04:41 PM
L
Leo99 Online Content
Online Content
L
Truth right there.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5071892 04/11/19 05:08 PM
U
Urshurak776 Offline
U
Don’t worry. Half the time they don’t bother to change your filter anyway. Caught the one up the street from our office doing it twice on the shop truck. Don’t go there anymore.
2012 Hyundai Santa Fe, 153,000 miles, Havoline Pro DS Full Syn 5W-20, COS3593A Champion Filter.
2014 Kia Rio, 85,000 miles, Havoline Pro DS Full Syn 5W-30, WIX Filter.
Re: Jiffy Lube And Oil Filters???? [Re: Urshurak776] #5072018 04/11/19 07:08 PM
U
Ursatdx Offline
U
That's probably a figment of your imagination.
Are you certain they only replace 50% of the filters?
Please refrain from making generalizations of an industry and persons that can not be substantiated.
This thread was going fine until the "Quick Lube" basher, you, had to chime in.
If you choose to do your own OFL's, that's fine.
Don't make up stories to try and influence those that choose to have someone do it for them.
I've made a fine living in the DIFM market.
We change every filter, every time.
p.s. Over the years BITOG has been a great educational tool for my staff and I.
Thanks to almost everyone.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Jiffy Lube And Oil Filters???? [Re: Donald] #5072041 04/11/19 07:28 PM
K
kstanf150 Offline
K
Sure is a lot of analyzing ever drop of oil processed on this website for an answer like that. Guess we’re all wasting a [censored] of a lot money on good oil and filters
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5072660 04/12/19 12:25 PM
N
nthach Offline
N
When I had to tote some used oil off to Jiffy Lube, it looked it was either Performax or Pennzoil - both are Puro products, but there were a few Microgards being used for "speciality" applications. I dunno about Oil Changer(a local Bay Area chain, might be in San Diego too), but the two local ones(Speed Oil Change Center and Speed Lube) use Service Champ, which can be made by Champ or Fram - which now is no longer the case since Fram split off Champ.
Re: Jiffy Lube And Oil Filters???? [Re: Willclark] #5072667 04/12/19 12:32 PM
N
nthach Offline
N
Case in point, ex-friend of mine had me do his oil changes - Speed Oil Change used Service Champ PH3593A and PH3980 equivalents. The former was a Fram with Champ markings, the latter was a Champ E-Core. Another friend takes her Subaru there(even though I said the dealer is better and often times than not, close in price), they've installed the thimble-sized Nissan filter that replaces a PH6607/7317 - it had Champ markings.
