Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
28 registered members (bachman, Delta, CB900F2, chuck172, Danno, DaHen, 3 invisible), 766 guests, and 34 spiders.
Topics306,229
Posts5,288,645
Members71,608
2002 Ford Ranger 2WD Coil Spring Upper Ball Joint #5070101 04/10/19 08:07 AM
DuckRyder Offline OP
Morning Ford Friends.
Can anyone verify if this is a “replaceable” ball joint, it appears it is using Moog (appears Ford NLA frown ) Part Number: K8738 .
[Linked Image]
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070132 04/10/19 08:24 AM
B
Blkstanger Offline
B
It looks nothing like the PN you listed. Does it have a snap ring on the under side? I'd guess the answer to your question is no.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070170 04/10/19 08:53 AM
T
Trav Offline
T
Honestly you are better replacing the whole arm, the bushing are also worn and by the time you change everything out it cost almost the same. Aftermarket will be okay for this application, it is adjustable for alignment. The sealed units from Proforged from Rock Auto are not very expensive and good quality.
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070239 04/10/19 10:10 AM
http://www.cfht.hawaii.edu/~grant/ranger/ball%20joint/install.html
Found this, mine look like this.
I’m not sure MOOG is using an exact picture. The bushings are actually OK, I’m pretty sure I have the body shop and their pickle fork to blame for the boots being destroyed. I will look for the snap rings in a bit, but I’m not sure the OE have snap rings.
Robert
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070242 04/10/19 10:17 AM
bdcardinal Offline
If it is an OE arm, there is no serviceable upper ball joint. All the aftermarket listings I show all have the not that they are for aftermarket arms only.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070249 04/10/19 10:21 AM
01rangerxl Offline
The flat/rectangular aftermarket arms are the ones where you can replace the ball joint. The OE arms were round and the ball joint could not be replaced separately.
As Trav suggested though, I'd just get replacement arms for the uppers and be done with it. That's what I've always done on these.
2002 Ford Ranger XLT | 3.0 V6 Auto 2WD | 239K miles
1994 Ford Ranger STX | 4.0 V6 Manual 4X4 | 203K miles
1994 Ford Explorer XLT | 4.0 V6 Auto 4X4 | 256K miles
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070265 04/10/19 10:35 AM
If I do replace the whole arm, are pro forged better than Moog - looking for quality over price.
Robert
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070296 04/10/19 11:05 AM
T
Trav Offline
T
Yes! Usually made in Taiwan but to a high standard, I have had no issues with them on any car I have used them on. The Moog can come from anywhere these days and quality is not consistent sometimes even between 2 parts with the same part number. This is not the old Moog company when the parts were always good, that got sold.
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: Trav] #5070303 04/10/19 11:12 AM
Originally Posted by Trav
Yes!
Thanks Trav. I assume they look stockish?
To answer the question about snap rings, not on the upper joints, and I’m pretty sure they are OE arms.
Hit the link i posted above and let me know what y’all think of it... (not mine) found it googling "ford ranger 2wd replaceable upper ball joint”
Bdcardinal, thanks as well assuming you do show Ford upper arms NLA?
Robert
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070318 04/10/19 11:25 AM
bdcardinal Offline
Yes!
Not only are they NOT obsolete, I have a pair sitting right next to me for our hoopty Mazda B-series delivery truck. If a parts person told you they are obsolete, they need to look into a different line of work.
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070351 04/10/19 11:55 AM
B
benjamming Offline
B
When I did this work on my 2001 Ranger back in October 2013, I used Moog which has 2 lines.
K80054 & K80052 were made in the USA.
RK80054 & RK80052 were made in China.
~ $25 difference in each arm. RockAuto had the US made ones for $55 each.
'16 Toyota Highlander 2GRFE/U660F
'02 Honda Accord J30A1/B7XA
'01 Ford Ranger 4.0L/5R55E
'94 Pontiac Grand Am 3.1L/4T60E
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070419 04/10/19 12:41 PM
01rangerxl Offline
The truck in the link has the original style round arms where the joints are not supposed to be replaceable. It does look like your truck still has those as well. Apparently whoever created that page was successful at it though, and the NAPA number they used crosses to the Moog number you posted and that is on Rock Auto, so I don't know.
If I remember right, the issue on the Ranger forums years ago was that the press fit was extremely tight, so it was generally more trouble than it was worth to even try anything other than just replacing the arm.
Judging from the pic Bdcardinal posted, Ford has since changed their design to something more closely resembling the aftermarket arms with rectangular arm sections instead of perfectly round, but that ball joint doesn't look like it's going anywhere!
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: benjamming] #5070746 04/10/19 06:11 PM
K
Kruse Offline
K
The Moog "R" line is their economy line to compete (price-wise) with all the other stuff coming from China. That being said, I've got Moog Problem Solvers on the front of my '98 Ranger that I completely rebuilt several years ago. They've been good for +100K miles and my Ranger drives really smooth down the highway.
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070832 04/10/19 07:29 PM
Sorry for the the radio silence, been in the middle of spring bushings and CalTracs...
I appreciate the feedback, I’ll check out the pro forged and see wha they cost, honestly if I can get the MC I’ll probably do that...
Robert
Re: 2002 Ford Ranger 2WD Coil Spring Upper Ball Joint [Re: DuckRyder] #5070847 04/10/19 07:40 PM
T
Trav Offline
T
Believe it or not you may find the dealer is cheaper or almost as the same price as rock when you include S&H. Always check with the dealer first, if you have no connections for a % off look at the ones online. I got a brand new, not reman PS rack for a VW from a dealer for $250 less than a Cardone reman from AA or Rock, granted they were blowing them out of the system but it happens quite often.
If not the Proforged is the better bet IMO, I see how they hold up in the salt belt and there is no comparison, the finish on them holds up as well or better than OE.
The joints boot and bushings are also high quality, not cheesy low end bushings like the Moog. I was a Moog guy for decades, they were the go too but bad things happen to good companies.
