I've started to notice more OEM-equipped air filters or OEM replacement air filters that glue a foam pre-filter to the bottom (dirty side) of paper panel filters. 2 examples come to mind.
The panel filter used for the Malibu 2.0 LTG (at least on the 2013-2015 2.0 Turbo LTG) and the 2013-up Ford Fusion/Edge/Continental/MKZ 2.0/2.7/3.0 as well as the Ford GT (the supercar, uses a pair of the Fusion filters, one for each turbo). The factory filter for my Fusion Sport (2.7 Ecoboost V6) is just a paper panel filter, but the Motorcraft replacements have a foam pre-filter.
Any ideas on these? I understand turbochargers will draw as much air as they need, but the extra pressure drop on a tuned vehicle could mean less efficiency. On the Malibu's stock filter with the foam, I noticed dirt/leaves starting to collect around the foam at the pleats as if the foam was restricted. There's no easy way to tap out the dirt from the foam.
