belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
21 registered members (AndyB, domer10, harry j, GMguy84, blufeb95, Bailes1992, 3 invisible), 1,362 guests, and 18 spiders.
Topics301,895
Posts5,204,865
Members70,798
Castrol Edge 5W-30 SN Plus (VOA) #5069704 04/09/19 06:59 PM
dustyroads Offline OP
Looks mostly the same as the d1G2 version I posted last year. Probably nothing more than batch variation between them.
Castrol Edge 5W-30 SN Plus / dexos1 Gen2
Code
             SN Plus/d1G2         SN/d1G2
Copper             0                 0
Iron               1                 1
Chromium           0                 0
Aluminum           0                 0
Lead               2                 0
Tin                0                 0
Silicon            9                 5
Sodium             4                 0
Potassium          8                 4
Boron             60                49
Moly              72                70
Nickel             0                 0
Silver             0                 0
Titanium          10                 9
Calcium          692               907
Magnesium       1498              1492
Zinc             814               715
Phosphorus       689               566
Barium             0                 0
Oxidation %       10                10
Nitration %        5                 5
Sulfation %       15                17
[email protected]°C     10.3 cSt          10.5 cSt
TAN              N/A              2.90
TBN              N/A              10.1
PQI               8                 3
ISO code       22/20/17         21/19/15
4 micron        28030            17372
6 micron         9727             3650
10 micron        2803              830
14 micron         821              229
18 micron         383              116
21 micron         251               81
38 micron          52               19
50 micron          34               11
2013 F150 XLT 5.0 4X4 122k miles
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: dustyroads] #5069712 04/09/19 07:05 PM
double vanos Offline
Thanks for posting! approved
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: dustyroads] #5070231 04/10/19 09:03 AM
T
Triple_Se7en Offline
T
Their really low Calcium and super-high Magnesium numbers are unlike any other SN Plus / Dexos1 Gen2 VOA I've seen.
So I bought ^this^ a few weeks ago, to try out.
Trolled Here? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai SantaFe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / Mobil1 Filters
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: dustyroads] #5070735 04/10/19 05:03 PM
B
buster Offline
B
You’re right Triple. They are using higher Mg and lower Ca. M1 is using the reverse with about 1,200 ppm of Ca and 600 ppm of Mg.
https://www.bobistheoilguy.com/foru...obil-1-sae-5w-20-api-sn-plus#Post4916989
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: Triple_Se7en] #5072500 04/12/19 09:44 AM
For those who didn't see the first VOA I posted last year, I wanted to assure everyone that I didn't mix up the calcium and magnesium numbers. They are listed accurately. It seems so different from everything else, maybe some are questioning those numbers.
Also, the lab was Milton Cat (based in Massachusetts). I drop off my samples at their Binghamton NY location and they get them to the lab for me. It saves dealing with the USPS.
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: dustyroads] #5072982 04/12/19 05:57 PM
T
T
You are sticking with it continuously. So obviously you're liking the results.
I bought this one, plus other major brands of SN Plus / Dexos oils. My factory-fill is coming out tomorrow and I think you just talked me into using my Castrol Edge 5w30 first.
I had planned to lead-off with Mobil-1 EP. But I don't want to crack the cap seals loose until that rebate check arrives. If it doesn't arrive, I'll return my two jugs of Mobil-1 EP to Walmart.
My Colorado will see Castrol Edge next month too. Except I'm using / trying out the 0W40 there. I'm taking a year-off from blending, inside all my OCIs. Been mixing oils for almost 30 years and it's time to take a vacation from it.
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: Triple_Se7en] #5074987 04/14/19 05:41 PM
Yes, very much. I'm anxiously awaiting the results from my 13k mile OCI, but the engine sure seems to like it. The little coyote had to "acquire a taste" for it, though. I filled it with 8 qts last May and after 1400 miles, it was down a half quart, so I topped it off. After 7900 miles, I added perhaps 6 ounces (3 oz had been vacuumed out for a sample). It never dropped below the full mark after that.
It turned dark very early in the OCI. When I drained it at 13k, it was kinda ugly but not scary looking. I'll post the UOA results no matter how they turn out, good or bad.
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: dustyroads] #5075069 04/14/19 06:57 PM
T
T
Next time have six beers and three Schnapp chasers before viewing the oil. That's when the ugly ones start looking pretty good to many.....lol
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: Triple_Se7en] #5077610 04/17/19 08:22 AM
LOL... check the oil with beer goggles on, huh? I only have a single bottle once in a while, so that won't work. I'm used to seeing black HDEO, so I don't get too worried about the looks of the oil, but it was the darkest PCMO I've ever seen.
Re: Castrol Edge 5W-30 SN Plus (VOA) [Re: Triple_Se7en] #5084843 04/24/19 01:31 PM
E
Env1ous Offline
E
I am really liking this oil. I saw someone gave a MSDS and it is group II and group III but that was from 2017. I would guess it has changed since then. I think I am going to give this a try.
