Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
119 registered members (apollo18, 928, 2012AccentSE, aquariuscsm, Anduril, ABomb369, 9 invisible), 2,278 guests, and 21 spiders.
Topics301,698
Posts5,200,852
Members70,759
VOA Valvoline Transfer Case Fluid #5069651 04/09/19 05:47 PM
dustyroads Offline OP
Valvoline says good for Ford XL-12, GM Auto Trak II and ATF+4 applications
Code
Copper              0
Iron                0
Chromium            0
Aluminum            0
Lead                0
Tin                 0
Silicon             5
Sodium              6
Potassium           0
Boron             282
Moly                0
Nickel              0
Silver              0
Titanium            0
Calcium           225
Magnesium           8
Zinc               10
Phosphorus        562
Barium              0
Oxidation %        16
Nitration %         5
Sulfation %        24
Viscosity @ 100°C     6.3 cSt
PQI                 7
(Particle Quantifying Index)
ISO code        22/20/16
4 micron          21624
6 micron           7006
10 micron          1626
14 micron           478
18 micron           236
21 micron           168
38 micron            56
50 micron            38
2013 F150 XLT 5.0 4X4 122k miles
Re: VOA Valvoline Transfer Case Fluid [Re: dustyroads] #5069745 04/09/19 07:39 PM
G
GSCJR Online Content
Online Content
G
Thanks for posting Dusty. Hmm; Wondering if I can use this in a Honda diff. Maxlife is what I was leaning towards trying.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 156KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 176KM
Re: VOA Valvoline Transfer Case Fluid [Re: GSCJR] #5070010 04/10/19 05:42 AM
You're welcome. The last time I looked, Maxlife and this transfer case fluid looked identical on Valvoline's product info sheets. I thought maybe it was the very same product, just bottled/marketed for two different things.
Re: VOA Valvoline Transfer Case Fluid [Re: dustyroads] #5071125 04/11/19 04:22 AM
dnewton3 Offline
Global Moderator
Global Moderator
Back more than 10 years ago, GM quit licensing Dex III(h) in 2006 in deference to their "new" Dex VI. Ford stopped licensing Mercon, opting for the Mercon V. But because GM had been using their DEXIII ATF as their transfer case fluid, they had to come out with a "Transfer Case" lube for OTC parts sales. All they did was bottle up the former DEX III and relabel it as "Transfer Case" fluid. Ford did something similar after LV came out; not sure if they still are doing it.
It would not surprise me at all if Valvoline is bottling Maxlife ATF as "Transfer Case" fluid for many applications. That's because ATF was, and still is, a primary lube in many, many t-case applications across many OEMs.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: VOA Valvoline Transfer Case Fluid [Re: dustyroads] #5072122 04/11/19 09:22 PM
U
userfriendly Offline
U
When I need power steering or transfer case fluid, I drain it out of my Allison transmission (TES295 spec) and put the new fluid in.
Re: VOA Valvoline Transfer Case Fluid [Re: dnewton3] #5072462 04/12/19 09:12 AM
While I did get a discount on the transfer case fluid, it's much more expensive to buy compared to Maxlife. I think next time, I'll just buy a gallon of Maxlife and use that (unless Molakule comes along and says it's a bad idea). smile
Re: VOA Valvoline Transfer Case Fluid [Re: userfriendly] #5072482 04/12/19 09:28 AM
I looked at Delvac ATF (a TES295 spec fluid) and see it's a 7.3 cSt fluid. Maybe I should consider something like that in my t-case.
I've never opened up a T-case but aren't they just chains and sprockets (at least the basic shift on the fly versions like mine)? Maybe the fancy t-cases with an "auto" position have more specific requirements for some sort of clutches?
Re: VOA Valvoline Transfer Case Fluid [Re: dustyroads] #5072910 04/12/19 04:43 PM
U
U
I'm using a clone TES295, Petro-Canada Duradrive.
My daily driver, a 2011 GMC 2500 6.6L sees about 3,000 miles of 4X4 use in deep snow and icy conditions a year. 275/65/20 Hankook RW-11s
My son's 2013 1500 GMC SLT 5.3L, more off-road than on. 275/60/20 Nitto EXOs
Both have over 100,000 miles.
Diff fluid; both 80W140 Petro-Can, Transfer cases, PC Duradrive.
If there was going to be an issue with these fluids, I'm sure it would have showed up by now.
I bought a pail of Chevron 80W140 for 3 3500 GMC 6.0L company vehicles. one has 245/70/19.5s.
The locomotives use 20W40 Chevron, ZDDP free.
Re: VOA Valvoline Transfer Case Fluid [Re: GSCJR] #5073212 04/12/19 11:03 PM
MolaKule Offline
Global Moderator
Global Moderator
Whoaa, you might want to rethink that unless you are speaking about a transaxle that uses one of those LV fluids.
Most differentials require at least a 75W85 GL-5 grade of gear oil. This fluid has an equivalent GL-4 rating.
I'm a Student Pilot. Frightening, isn't it?
Re: VOA Valvoline Transfer Case Fluid [Re: dnewton3] #5073256 04/13/19 01:20 AM
B
BlakeB Offline
B
I think what GM is using now for transfer cases, power steering, and manual transmissions is Dex III(K) (GMW17639). If what they are selling as “Manual Transmission and Transfer Case Fluid” is in fact Dexron III(K) as I suspect, it is not the same as Dexron III and should not be used in an automatic transmission. They apparently pulled the additives (I assume that means friction modifiers) out of this fluid as they aren’t needed for its intended applications.
GM part no. 88861800
I did a little more looking, looks like the Ford Transfer Case Fluid is called XL-12. It looks like it has been discontinued by Ford.
Re: VOA Valvoline Transfer Case Fluid [Re: BlakeB] #5073263 04/13/19 01:37 AM
4WD Offline
Have 2017 & 2018 full sized GM's ... both take Dex VI in the transfer case ...
Re: VOA Valvoline Transfer Case Fluid [Re: dustyroads] #5073273 04/13/19 02:38 AM
B
BlakeB Offline
B
Last time I looked, the Maxlife ATF PDS shows that it can be used in the place of Autotrak II which is what GM uses in their “auto” transfer cases. Valvoline “recommends” Maxlife for lots of things, which isn’t to say that it’s necessarily the best choice for a given application but it should work.
Re: VOA Valvoline Transfer Case Fluid [Re: 4WD] #5073279 04/13/19 02:55 AM
B
BlakeB Offline
B
The newer GM’s take Dexron VI, the problem is that Dexron VI isn’t backspec’d for use in manual transmissions or transfer cases that called for Dexron III. You can use Dexron VI for transmissions that previously called for Dex III, except for some pre-07 Allison 1000’s in GM HD pickups. I think GM actually started using Dex 6 in the Allison’s sometime in 06, anything serial number 6320784373 and above can use Dexron VI. The older Allison’s had a different type of seals made of a different material which will harden and eventually leak if you use Dexron VI in those units.
There is a lot of good information HERE.
Re: VOA Valvoline Transfer Case Fluid [Re: BlakeB] #5073285 04/13/19 03:33 AM
4WD Offline
Yep my first was an 85 and a bunch in between .... used Mobil 1 through the Dex III era, but after Dex VI used that - or Valvoline or Castrol MV ATF's ...
Did have one transfer case use Synchromesh .... Ran Redline in that ...
Re: VOA Valvoline Transfer Case Fluid [Re: MolaKule] #5074008 04/13/19 07:53 PM
G
Online Content
G
Hey Mola,
Honda uses that secret sauce for their diffs. I used Dexron in my old CRV.
I have an 08 at work now needing a service.
