P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
69 registered members (aquariuscsm, AurionX2, ArrestMeRedZ, 4WD, 94astro, alchargo, 5 invisible), 1,538 guests, and 33 spiders.
Topics306,051
Posts5,286,412
Members71,593
Axle / CV Driveshafts #5069437 04/09/19 03:21 PM
diyjake Online Content OP
OP Online Content
I need to replace the passenger side axle on my 2009 Camry. OEM is out of the picture because they are around $400-500. Raxles are good but they don't have any for Toyota's. So my last options are Cardone from Rockauto or Napa MaxDrive.
I do want to try to get one with Heavy Duty Thermoplastic boots but my question is should I get a new Cardone / Napa MaxDrive or remanufactured / rebuilt one? Which one would be better?
Re: Axle / CV Driveshafts [Re: diyjake] #5069445 04/09/19 03:26 PM
A
ad244 Offline
A
Napa new are the best
Re: Axle / CV Driveshafts [Re: diyjake] #5069448 04/09/19 03:29 PM
SatinSilver Offline
How do you know you need a new one? I ask because I'm getting a rumbling noise when driving straight ahead in the 05 Matrix. Could be tires, wheel bearing, etc...in my car.
Not sure which brand is best since no experience with them.
Re: Axle / CV Driveshafts [Re: diyjake] #5069458 04/09/19 03:36 PM
OP Online Content
Well I think it is my axle, boots are fine but I am getting a clicking / grinding noise, maybe it is the bearing on the axle. Either way I will need to pull it off and see what is going in there.
Re: Axle / CV Driveshafts [Re: diyjake] #5069465 04/09/19 03:40 PM
slacktide_bitog Offline
Rock Auto has the Cardone HD axles. The HD line uses thermoplastic boots, like OE.
Most reman, including Cardone's standard reman, use neoprene, which is inferior.
I mention this because torn boots are virtually the ONLY reason for CV joint failure
Re: Axle / CV Driveshafts [Re: diyjake] #5069474 04/09/19 03:50 PM
OP Online Content
Thermoplastic boots are a must and both Cardone and Napa MaxDrive offer them. Napa MaxDrive is about $30 more but might be worth in case I need warranty?
Re: Axle / CV Driveshafts [Re: diyjake] #5069515 04/09/19 04:22 PM
The Critic Offline
I would purchase a used low mileage, OEM axle from ebay and install new boots. This is your best option.
I have re-booted many of the passenger side CV axles for this application but I have never seen one that is noisy.
As an alternative you can try CVJAxles:
https://www.cvjreman.com/
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Axle / CV Driveshafts [Re: diyjake] #5069567 04/09/19 05:22 PM
P
PandaBear Offline
P
If you cant' get a new OEM, pull from junkyard or ebay.
$400-500 is about right, OEM remand if offered would be almost $200 ea. This is one part you don't want to cut corner on (unless you are just fixing to trade in).
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Axle / CV Driveshafts [Re: diyjake] #5069574 04/09/19 05:32 PM
N
NormanBuntz Offline
N
Be cautious if the Napa Maxdrive axle is made or remanufactured by Cardone. I had one installed on my Ridgeline that had a Cardone warranty, and I ended up swapping it out for a Honda OEM axle because the Maxdrive had a noticeable vibration at 50 mph. Maybe that won't be the case for your Toyota.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Axle / CV Driveshafts [Re: diyjake] #5069593 04/09/19 05:57 PM
P
PurpleT Offline
P
I have used CVJ several times in the past for cv shafts for my Camry and Tacoma. Excellent service and high quality parts. I would second what has already been said about the reman axles and would suggest you follow the advice provided by The Critic and others.
Re: Axle / CV Driveshafts [Re: PurpleT] #5069687 04/09/19 07:31 PM
OP Online Content
How much did this cost? Do you send your axle in and have them rebuild it or due the sell rebuilt axles?
Re: Axle / CV Driveshafts [Re: diyjake] #5069700 04/09/19 07:58 PM
M
mclasser Offline
M
Aftermarket axles are a crap shoot.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Axle / CV Driveshafts [Re: diyjake] #5069702 04/09/19 07:58 PM
H
HoosierJeeper Offline
H
The issue I've seen with new ones of any make is them being too short or too long. Granted, that's just what I've seen on the Liberty forum I run, so we usually recommend Napa remans since at least you get an OE core. The wrong length plays havoc on the Libertys, especially if running a lift and off roading.
19 Jeep Renegade Trailhawk 1.3T
15 Jeep Cherokee Limited V6
07 Land Rover LR3 SE V8
05 Jeep Liberty Limited V6
96 Jeep Cherokee Country 4.0
