Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
30 registered members (4WD, ChristianReske, ctechbob, BlakeB, 3311, Bailes1992, 4 invisible), 765 guests, and 25 spiders.
Topics293,635
Posts5,043,825
Members69,025
Most Online3,532
Jul 30th, 2019
Page 2 of 3 1 2 3
Re: Timing chain [Re: SHOZ] #5068601 04/08/19 06:49 PM
das_peikko Offline
Isn't there supposed to be a fixture or a special tool to keep the cams from rotating while you get everything else in position?
Re: Timing chain [Re: das_peikko] #5068604 04/08/19 06:53 PM
SHOZ Offline OP
The cams have a hex as most do. The way the chain is put on (counter clockwise) you start with the chain on the crank sprocket then move the cams just a bit to match the chain and when done it's all lined up. But I did stick a screwdriver under one lobe on the exhaust cam to secure it.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Timing chain [Re: das_peikko] #5068633 04/08/19 07:22 PM
K
kschachn Offline
K
Never mind, Shoz answered it well.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: Timing chain [Re: SHOZ] #5068694 04/08/19 08:31 PM
A
aquariuscsm Offline
A
That's a clean engine! What's your go-to oil?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Re: Timing chain [Re: aquariuscsm] #5068720 04/08/19 08:59 PM
SHOZ Offline OP
Thanks. I use Mobil 1 and 5k mile OCI. Fram Ultra since they came out. 0W40 for the last few years, 5w30 for a couple of years.. But always has been synthetic since I dumped the factory fill. (5w20)
Here's the cams before I started.
[Linked Image]
And the amount of slack.
[Linked Image]
It takes the same chain as a Dodge and Mitsubishi motor, from their one time shared production or design arrangement.
Re: Timing chain [Re: SHOZ] #5068778 04/08/19 09:51 PM
9
92saturnsl2 Offline
9
Ouch only 97k for a chain?
I used to own a Dodge Caliber SRT4 with the 2.4L turbo World Engine, same family as this one I believe. Nice engines, very reliable. Is this engine known for eating chains/tensioners or is this an aberration?
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40
04 Odyssey EX 190k Valv. Durablend 5w-30
96 Maxima GLE 265k Chevron Delo LE 5w-40
07 Chrysler Pacifica Limited 4.0L 140k Belgian Castrol Edge 0w-30 Euro
Re: Timing chain [Re: 92saturnsl2] #5068785 04/08/19 09:58 PM
SHOZ Offline OP
That's the connection. The OE chain I got is shared with the Sonata 2.4L motor too.
Re: Timing chain [Re: SHOZ] #5068846 04/08/19 11:36 PM
slacktide_bitog Offline
Nice pictures! thumbsup
IMO, if you didn't put the engine back together yet, you are probably still better off buying the new chain. Especially if the original needed replacing before 100k. There are *belts* that last longer than that mad
It seems like a difficult job that you definitely don't want to do again!
Re: Timing chain [Re: SHOZ] #5068993 04/09/19 06:57 AM
A
aquariuscsm Offline
A
[Linked Image]
[Linked Image]
Honestly that engine is spotless! It looks like a brand new engine. No wear whatsoever on the camshafts. That must be a really good engine!
Re: Timing chain [Re: SHOZ] #5068994 04/09/19 06:58 AM
A
aquariuscsm Offline
A
Have you been able to tell any difference between the oils you use? M1 0W40 is something I've always been curious about but have never tried it.
Re: Timing chain [Re: slacktide_bitog] #5068999 04/09/19 07:05 AM
SHOZ Offline OP
If I didn't want to throw away the $50 the chain I got was and the better chain is $75 I would have. I doubt if the car sees another 100k miles at least with me driving it. smile I don't drive it near as high as I did when it was new. It's suspected the chain wasn't designed for the higher rpm (7500) vs the Sonata 2.4L that the OE chain was picked off the parts shelf from.
10 years or so ago I did a V8 with DOHC but it was out of the car at the time.
Re: Timing chain [Re: aquariuscsm] #5069005 04/09/19 07:14 AM
SHOZ Offline OP
I started out using M1 5w30. Had a couple oil test done and dilution was the only problem. One test was done after two track days and a 5k mile drive in between. The engine will actually 'make' oil as the dilution adds faster that if burns any oil , if any. Loose rings and high compression design I guess.
Re: Timing chain [Re: SHOZ] #5069349 04/09/19 01:50 PM
Z
zorobabel Offline
Z
Anyone remember this thread?
1997 Maxima 206k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 205k, VWB 5W-20-30, MGL4967
Re: Timing chain [Re: SHOZ] #5069351 04/09/19 01:55 PM
SHOZ Offline OP
Just for the record Hyundai has come out with a beefier chain but when I ordered it got the old part. Didn't know until after I got it. Mitsubishi had problems too with their Evo motors that had the same chain.
Re: Timing chain [Re: SHOZ] #5074832 04/14/19 04:22 PM
SHOZ Offline OP
Just want to say it all is back together and runs!.. I'm always nervous. Only the second time for a chain on a DOHC engine for me. Thanks for the help.
Couple of pics of the oil pump.
[Linked Image][Linked Image]
Page 2 of 3 1 2 3
