Hello guys, It's me again, I just update my previous thread regarding my brake line repair and bleeding. But I have another question for you for a new problem.
https://www.bobistheoilguy.com/foru...need-brakes-specialist-helps#Post5057684
To make a story short of my endeavour, I was able to change the two rear brake lines of my beater. I was also able to crake open 3 of 4 bleeders. As for the one I had broken, it was for me way cheaper ($15) and time saving to buy another brake cylinder instead of trying to extract the stuck bleeder. It was a pain in the (edit- mod) and I also almost broke two very frozen fitting as well. In short, It was an epic battle between me an the rust and It took me almost two days to finish the job. I was so proud and happy that I was able with success to repair the brake line in a first try and I Iearn lot of new stuff.
Sadly today, another brake line had ruptured (under and in the middle of the car). This time, I decide to cut all rotted brake lines and replace them with new one. I have some tubing experience and I'm very confident that I will be able to flare the new brake line. The only problem I still need to figure out is what type of brake line I need. In fact, when I was "shopping" for the new brake line in amazon and in my local stores, there are a plethora of type of brake line. I don't need some fancy brake line for my beater. But I don't want either to buy some crappy brake line which gets rotted by the rust in 2 or 3 years. The over all condition of my beater is still "excellent' and I plan to keep it for another 5 years.
As I had mentioned in my previous thread, I'm still a noob regarding braking system. For now, the only conditions which come up in my mind regarding the brake line are the brake line must able the withstand the corrosion for at least 5 years. It must be also easy to bend and easy to flare. Finally the brake line must be also "legal". If you have some experience regarding the brake line characteristics, please share your knowledge. thx
