98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
24 registered members (Bjornviken, chemman, csandste, ArrestMeRedZ, Bailes1992, clinebarger, 2 invisible), 641 guests, and 20 spiders.
Topics292,010
Posts5,015,199
Members68,692
Most Online2,967
Mar 10th, 2019
ACDelco PF63E cut open #5064419
04/04/19 06:04 PM
04/04/19 06:04 PM
Prosper, TX
K20FA5 Offline OP
K20FA5  Offline OP
Prosper, TX
Changed the oil in my truck today. This was put in at 2,000 miles and drained today at 5,500 miles. 3,500 on this filter. Oil was PP 0W-20. Put back in PP 0W-20 and another PF63E.
I plan on running this one out till the OLM tells me to change it. With the rate this one was going, should be right before (or at) 6,000 miles. I’m also going to do an UOA on the next drain. The engine should have around 11,000 miles at that point.
I’m very happy with how this filter looks. No complaints at all.
The dirt specs are from my dirty old baking tray I stole from the kitchen and have hijacked in the garage now. Shhhhhh wink
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Mine-2018 Chevy Silverado LT Z71 5.3L-M1 AFE 0W-20 / PF63E
Wife-2016 Toyota 4Runner SR5 Premium 4.0L-M1 AFE 0W-20 / 04152-YZZA5
Kiddo-2012 Honda Civic LX 1.8L-PP 0W-20 / TG7317
Re: ACDelco PF63E cut open [Re: K20FA5] #5064436
04/04/19 06:19 PM
04/04/19 06:19 PM
MN
oil_film_movies Offline
MN
Nitrile ADBV, they are cheaping-out on us. At least no hole in that E-core. Always found it strange an ACDelco PF63E has that two-layer metal "shelf" around the outlet like that. .................
Do that nice Silverado a favor and use the better Wix WL10255 or the napaGold equivalent. Filters better, silicone ADBV, never had any holes reported in it, compared to ACDelcos which sometimes have holes.
Re: ACDelco PF63E cut open [Re: K20FA5] #5064462
04/04/19 06:48 PM
04/04/19 06:48 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Something weird with those seam pleats, that angle from top to bottom isn't good. Hopefully not torn?
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: ACDelco PF63E cut open [Re: K20FA5] #5064477
04/04/19 07:04 PM
04/04/19 07:04 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
There is absolutely nothing wrong with this filter. A materials bias? OK, i understand some don't like ecore. But the build quality and how it held up? No issue.
2018 KIA Sportage LX 2.4 AWD:
Now:QSAD 5W-20, PH9688
Next: M1HM 10W-30, PH9688
2013 Hyundai Santa Fe Sport 2.0T:
Now: PP 5W-30, OE
Next: M1HM 10W-30, COS3593A
Re: ACDelco PF63E cut open [Re: bullwinkle] #5064491
04/04/19 07:19 PM
04/04/19 07:19 PM
Prosper, TX
K20FA5 Offline OP
K20FA5  Offline OP
Prosper, TX
It seems like it got off when glued. There is no torn media at all on the inside. I was worried at first when I saw it, but it seems ok.
Re: ACDelco PF63E cut open [Re: K20FA5] #5064494
04/04/19 07:20 PM
04/04/19 07:20 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
For the oil drain interval, The AC Delco will do just fine.
2002 Silverado 5.3 0w-20 AMSOIL
Re: ACDelco PF63E cut open [Re: K20FA5] #5064514
04/04/19 07:38 PM
04/04/19 07:38 PM
Texas
GM4LIFE Offline
GM4LIFE  Offline
Texas
Why not go with the Fram Ultra? Thats a much better filter internal wise.
Re: ACDelco PF63E cut open [Re: K20FA5] #5064520
04/04/19 07:42 PM
04/04/19 07:42 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Glad to see the eCore filter makers know how to make a center core these days.
Re: ACDelco PF63E cut open [Re: GM4LIFE] #5064944
04/05/19 09:09 AM
04/05/19 09:09 AM
MN
MN
True, normally.. On GM engines made in the last 5 years, GM has been strongly suggesting you need a bypass pressure threshold around 22 psi. The https://www.fram.com/parts-search/XG10575/ Ultra PF63E cross-reference is still listed as starting to open at 16 psi, so its too low. ....
We have speculated that this is only a problem in cold weather, as in around 20F or lower, when the oil is super thick and the oil filter on startup gets a pressure spike that dislodges junk on the dirty side of the oil filter to wash directly into the enigne. I can only estimate this won't be a problem with a low-bypass Ultra in non-freezing temperatures. Safer to use the Wix or NapaGold oil filter which cross references to the PF63E, since Wix has the correct bypass pressure.
GM's TSB on the whole filter bypass pressure issue explained their use of a newer pressure control system (sensor placement) that caused them to worry about washing junk into the engine thru popped bypass valves.
Re: ACDelco PF63E cut open [Re: K20FA5] #5065032
04/05/19 10:49 AM
04/05/19 10:49 AM
Bad Axe, MI
daman Offline
daman  Offline
Bad Axe, MI
In your last pic you can clearly see through the cage that the pleats are bowing/stressed, I cant believe there sending that kind of pressure through a escrap. Good luck! I wouldn't run that filter longer then 3k.
"Always"....Mobil 1
Current fill: AFE 0w30
Re: ACDelco PF63E cut open [Re: K20FA5] #5065173
04/05/19 12:59 PM
04/05/19 12:59 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Quote
Assume reference to auxiliary baseplate over other main plate. When Champ added it, said used to make installation easier on blind/hard to see engine mounting stud applications. That as opposed to non beveled raised thread boss on filter, without extra plate. The latter similar to that currently used on Fram 7317/4386 series filters. At least that's how Champ explained it.
Topic filter looks ok. Uses GM ACDelco separate poppet bypass type as opposed to combo valve used on equivalent non ACDelco ecore filters like Super Tech.
Thanks for c&p.
Re: ACDelco PF63E cut open [Re: oil_film_movies] #5065319
04/05/19 03:15 PM
04/05/19 03:15 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Yep, the actual delta-p vs oil viscosity & flow is a big part of what determines the bypass valve opening pressure. It could also be that the AC Delco filters are a bit flow restrictive which makes the delta-p higher, so therefore the bypass valve also needs to be set higher.
What then happens is that particular design point on just AC Delco filters then "defines" what all aftermarket filter bypass valves "need to be set to" ... even though there is no actual "flow vs delta-p" data to confirm or deny that is actually required for every other filter brand made for that specific engine application.
