Wanted to post a UOA with filter pictures and did a little experiment. I used 4 neodymium magnets rated for a 45 lb pull around the filter to see if it would reduce the iron. It did not, not total, nor per mile. I ran out of 5W-20 oil and with it burning more oil I switched to 5W-30, so its not an apples to apples comparison to the previous oil change, oh well.
OIL Schaeffer Supreme 9000 with 5 quarts added. 2 quarts of make up oil were 5W-20, rest were 5W-30. Previous oil change was all 5W-20
MAKE UP OIL 5 qts 3 qts
MILES IN USE 11,996 12,034
MILES TOTAL 164,000, 152,000
SAMPLES TAKEN 1/19/19 and 5/8/17
Courtesy of Schaeffer Webscope
Code
Make up Oil(qts) 5 3
Miles 12k 12k
Date 1/19/19 5/8/17
IRON 44 29
CHROMIUM 5 3
LEAD 0 0
COPPER 13 13
TIN 0 0
ALUMINUM 14 8
NICKEL 2 2
SILVER 0 0
SILICON 16 8
BORON 7 1
SODIUM 200 227
POTASSIUM 3 4
MAGNESIUM 17 20
MOLYBDENUM 290 227
MANGANESE 1
ANTIMONY 39 19
CALCIUM 2289 1723
PHOSPHORUS 661 396
ZINC 746 931
BARIUM 0 0
WATER
OXIDATION 19.63 20.62
NITRATION 6.7 7.16
cSt @ 212F 8.45 8.64
You can see the circle where the magnet was on the outside. Pleats are wavy but no tears or holes that I could see.
Code
Miles 12k 12k
Date 1/19/19 5/8/17
IRON 44 29
CHROMIUM 5 3
LEAD 0 0
COPPER 13 13
TIN 0 0
ALUMINUM 14 8
NICKEL 2 2
SILVER 0 0
SILICON 16 8
BORON 7 1
SODIUM 200 227
POTASSIUM 3 4
MAGNESIUM 17 20
MOLYBDENUM 290 227
MANGANESE 1
ANTIMONY 39 19
CALCIUM 2289 1723
PHOSPHORUS 661 396
ZINC 746 931
BARIUM 0 0
WATER
NITRATION 6.7 7.16
