"New" Raw Water Pump From Amazon
by wings&wheels - 07/03/20 12:39 PM
Best refried beans?
by aquariuscsm - 07/03/20 12:16 PM
Northern hot cold pressure washer - clogged
by Donald - 07/03/20 10:48 AM
Porsche Transaxle Fluid Label
by wings&wheels - 07/03/20 08:52 AM
Ford 7.3 Godzilla Engine
by Snagglefoot - 07/03/20 08:43 AM
Growing Blackberries and Mulberries
by krismoriah72 - 07/03/20 07:50 AM
Yo! Starsky,
by RichR - 07/03/20 02:03 AM
Chinese air filters?
by Dogred08 - 07/03/20 01:18 AM
2006 Jetta TDI 5-speed with 324K miles in Florida
by atikovi - 07/02/20 10:51 PM
Rain X
by hardcore302 - 07/02/20 10:06 PM
K&N as for Trax MAF?
by hardcore302 - 07/02/20 09:46 PM
Auto Zone Delo 400 XLE 10w-30 1/2 off and rebate
by blupupher - 07/02/20 09:45 PM
RAM about to pass Silverado sales
by gfh77665 - 07/02/20 07:49 PM
Puffer Fish and Skate
by buster - 07/02/20 06:25 PM
ThaKid22, Speedeuphoria, 400rwkw, daveCarTruck, Jth383
71840 Registered Users
70 registered members (aquariuscsm, andyd, 55hambone, alarmguy, 2015_PSD, 928, 8 invisible), 2,210 guests, and 40 spiders.
Topics307,366
Posts5,309,902
Members71,840
Page 1 of 6 1 2 6
2010 F-150 5.4 3V- Issues imminent? #5064089 04/04/19 11:50 AM
P
panthermike Offline OP
P
Purchased this truck back in December and overall really like it. However, shortly after taking ownership; I've noticed some odd noises coming from the engine bay. The first is a cold start tick that has a similar sound to a dry start, lasts a second or two. I am running a motorcraft filter and swapped it with another; noise still there.
Second noise i've noticed is a "hot idle knock" after I start the truck when i've been running it for a bit. The noise subsides after a few minutes or so. Also in general, the idle of the truck isn't very "smooth". I can feel vibration through the steering wheel pretty much anytime it's idling.
From what i've read, many people point to the cam phasers. The fix is all over the map though, from phasers to a new motor. I tried 0w40 based on the potential issue of not enough oil pressure; no change. Does anyone have experience with these? Do you think more serious issues are imminent? The truck runs fine and seems to have ample power. Sitting at 100K right now and thankfully I do have a warranty up until 121K.
'17 Armada Platinum; RGT 0w20, 54K
'19 Ram 1500; RGT 5w20, 17K
'70 F100; Valvoline 15w40
Biotech For All
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5064107 04/04/19 12:11 PM
M
mattd Online Content
Online Content
M
Check your hot oil pressure. It needs a minimum of 25-30 psi to operate the cam timing. The issue is likely the phasers however depending on how extended the tensioners are will determine if you need a chain kit with the guides, sprockets and new tensioners. I suspect the seals on the tensioner(s) are worn and it takes a few seconds to build oil pressure in them to quiet the engine down. It’s really not a bad job. It will require removal of the timing cover and valve covers.
Your cold start tick (which I assume goes away when warm) is likely an exhaust manifold. Not a fun job.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5064160 04/04/19 12:54 PM
A
andyd Online Content
Online Content
A
Put some thicker oil in it at least 5 w 30, 10 w 30 would be better. grin2
Thick oil is better grin2
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: mattd] #5064179 04/04/19 01:10 PM
P
P
I may just take it in since it's under warranty if that's the possible culprit!
andyd, it has 0w40 in it now smile
Biotech For All
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5064241 04/04/19 02:07 PM
P
P
Matt, would the cold start tick go away so quickly with an exhaust leak?
Biotech For All
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5064243 04/04/19 02:09 PM
M
Online Content
M
How long does the tick last for? Manifold ticks will usually clear up in a few minutes or so depending how big the leak is. If it lasts only a few seconds it’s not an exhaust manifold. Probably related to the chain rattle on start up if it coincides with that
ASE Master, L1, L2
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: andyd] #5064274 04/04/19 02:55 PM
CT8 Offline
10w-40 is Fords recommendation for noisy cam phasers [what ever Ford calls them}
2015 F150 2.7
2018 F350 6.2
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5064295 04/04/19 03:18 PM
DoubleWasp Offline
I'd twist their arm to get your spark plugs changed too. You will not believe what a nightmare that can be. Change them fairly often, or you might not get them back out.
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: DoubleWasp] #5064335 04/04/19 03:56 PM
Cujet Offline
The 2009-10 5.4's have revised plugs/heads. No problems with the new design.
It sounds like your timing chain is loose. The tensioners are plastic with a captured O-Ring. This seal tends to blow out, leaking pressure.
The real fix is to replace everything from the oil pump, to the timing chain/tensioners/actuators to the phasers with 100% Ford parts and get another 100K from it. Don't bother with aftermarket phasers they don't hold up. The Melling high volume oil pump is excellent.
It's good to note that the OEM oil pump tends to leak oil from the backing plate and the leaky chain tensioners reduce oil flow to the heads even more. Unfortunately, some owners find a wiped out camshaft, due to lack of oil at the head.
10W-40 is the dealership fix. The real fix is mechanical.
In my case, I'm currently using 10W-30 M1 high mileage. It's reduced the cam phaser noise (which has been there since new) and so on. But it has not reduced the initial start roughness that is due to loose chains due to faulty tensioners.
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: mattd] #5064350 04/04/19 04:16 PM
P
P
Only 1-2 seconds, so I guess that would be timing chain.
Doublewasp, actually changed the plugs when i got the truck. Wasn't a bad job at all with the revised heads/plugs.
Sounds like I should take advantage of the warranty and bring it to Ford. The only difference is I will supply the Melling high volume pump. Thanks for all of the feedback, had a feeling it wouldn't be easy!
Biotech For All
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5064724 04/05/19 12:24 AM
DoubleWasp Offline
Goos to know they actually did something about that fiasco. Sounds like the phaser and pump issues made it through the cracks.
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5177310 08/02/19 08:48 AM
P
P
Well it happened...something anyways. On my way to work on Wednesday, suddenly a loud ticking/tapping sound accompanied with a loss of power and detonation on the highway. Took it to Ford the same day, still waiting on some news. Will post an update
Biotech For All
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5179397 08/05/19 08:43 AM
Hootbro Offline
Just wondering, what kind of warranty do you have on a almost 10 year old vehicle? Hope you get it sorted.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2018 Chevrolet Colorado Z71 3.6L (Dealer Bulk 5W-30)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: Hootbro] #5179495 08/05/19 10:40 AM
P
P
It's a drivetrain only warranty; covers all lubricated parts and any motor/trans/driveline parts.
Biotech For All
Re: 2010 F-150 5.4 3V- Issues imminent? [Re: panthermike] #5179502 08/05/19 10:49 AM
Hootbro Offline
If it is a third party warranty, just be careful as they may want to sub aftermarket parts for repair and not pay for OEM parts.
Page 1 of 6 1 2 6
