Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
21 registered members (Bailes1992, ctechbob, Falcon_LS, DrDave, BlueOvalFitter, esmitty82, 3 invisible), 801 guests, and 22 spiders.
Topics293,635
Posts5,043,830
Members69,025
Most Online3,532
Jul 30th, 2019
Page 3 of 4 1 2 3 4
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: ZeeOSix] #5046924 03/18/19 02:54 PM
W
webfors Offline OP
W
Originally Posted by ZeeOSix
Originally Posted by webfors
Originally Posted by Patman
Originally Posted by Snagglefoot
The 12060 has been released but instead of being the size of a 10575 which is just over 4 inches long it is the size of a 10060.This is from the Fram site. It’s only 3.3 inches long.
We knew it was going to be the same size as the 10060 all along though, as it's that same filter just with a 22psi bypass. It's meant to be a cross reference to the PF64, which is 3.3 inches long.
Since the 10575 is the GM/ATS V6 filter, you would think a 22psi version of that filter would be on the way too.
It is ...
https://www.bobistheoilguy.com/foru...alve-pressure-on-the-xg10575#Post5034093
Excellent! The 10575 with a 22psi bypass would be the perfect filter on the ATS.
Downside, without any markings on the box, I have no way to determine if it's the new or old filter. Fram should have put some indicator on the box, even if only for us nerds that would have to look closely.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5046941 03/18/19 03:09 PM
Z
ZeeOSix Offline
Z
As mentioned in that thread, look at the color of the bypass valve.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: ZeeOSix] #5046997 03/18/19 03:59 PM
W
webfors Offline OP
W
I have yet to find an XG in an unsealed box, unless it's sloppy seconds with a 10% discount.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5048380 03/19/19 08:57 PM
L
LEADED Offline
L
Well , so long for waiting got a Wix WL10290 with 22 lbs psi for my Equinox . Very easy to obtain no guesswork . End of story
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: LEADED] #5048387 03/19/19 09:05 PM
4WD Offline
Yep … and with sealed up boxes I’m not going to be guessing at … or able to look inside the XG10575 (color) so just ordered a dozen Albert Champion PF63E …
(feeding two L83’s)
BiL the big winner who will get a half dozen XG10575 for the ecoboost …
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: 4WD] #5048406 03/19/19 09:25 PM
L
LEADED Offline
L
Agreed Napa 100290 was only 82 cents more than (PF64 -paper) no brainer here . Personally I am skeptical using XG1057t because of warranty 2019 Equinox.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5063510 04/03/19 08:19 PM
G
GM4LIFE Offline
G
Nobody has these filters yet. Why? I have to keep using the paper media based PF64 on my CTS-V. Any info from Fram on when Walmart or Amazon will have the XG12060?
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5063760 04/04/19 06:48 AM
P
Patman Offline
Global Moderator
Global Moderator
P
Some people have mentioned being able to order the new XG12060 online but nobody has yet to see one in stores, even though it was supposed to be out in January. I thought I might find it at Walmarts in the US but I've checked a few now to no avail. I might just end up sticking with the NAPA Golds for a while.
2018 Corvette, 14k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 151k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,117k, GC 0w40 & Fram Ultra
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: LEADED] #5063787 04/04/19 07:12 AM
4WD Offline
Got the PF63e's for $4/each and free shipping - so when I get back to the USA - plan to cut a new one and make sure they look OK inside ...
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: Patman] #5063819 04/04/19 07:55 AM
L
LEADED Offline
L
Frankly , Fram blew it , I am not going to use a wrong product . We have agreed that 10060 might compromise your Engine @ 15psi . PF64 - Wix WL10290 are set for correct setting @ 22 psi . No more guessing till 12060 comes out ? Mabe when [censored] freezes over .
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5063886 04/04/19 08:44 AM
W
webfors Offline OP
W
Or just use an oversized filter with 50+ % more media to mitigate the potential of bypass events.
I was at the dealer yesterday for my regular service and mentioned I had a XG10575 on the car and that I wanted it back. I then asked them if this was a problem since it's the ATS V6 filter, which maps to the Champion COS10575 or COS10590 stash I have, and he said not at all. He said there would be no concern or warranty concern. I am going to email him to get it on record grin
I'm going to cut open a PF64 tonight and record the media area for comparison. I'm estimating the COS10590 has 50% more media.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5063993 04/04/19 10:03 AM
Snagglefoot Offline
Here it is in the PH version.
https://www.rockauto.com/en/catalog/chevrolet,2018,corvette,6.2l+v8,3437533,engine,oil+filter,5340
If you want the job done right......do it yourself.
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5065528 04/05/19 06:34 PM
G
GM4LIFE Offline
G
So far, Jegs is the only one that has them at $8.97 each.
https://www.jegs.com/i/Fram/410/XG12060/10002/-1
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: webfors] #5065543 04/05/19 06:54 PM
L
LMG1 Offline
L
Re: Fram XG12060 - GM 22psi spec Ultra coming soon! [Re: LEADED] #5065577 04/05/19 07:50 PM
A
Al Offline
A
[quote=LEADED Fram blew it , I am not going to use a wrong product . We have agreed that 10060 might compromise your Engine @ 15psi . PF64 - . [/quote]
I put 190K miles on a Subaru using 15psi filters when Subaru called for 22 psi. Unless you run a filter 50K miles you won't have to worry about it. I use the Ultra in my '18XT Forester.
Page 3 of 4 1 2 3 4
