Years ago I owned a 1996 Suburban with the Vortec 350. I bought it for $500 knowing it had a bad transmission, and knowing it had a questionable maintenance history. The previous owner did overheat the engine, and had fresh heads installed when I purchased it. I replaced the tranny in it at 145,000 miles and drove it another 15,000 before a rod knock in the engine surfaced. I put a new (salvage yard) engine in it and drove for another 30,000 miles before selling it - nearly 10 years ago now. Anyway, I've been going through a bunch of old stuff and found that I had kept the knocking rod bearing I found when I pulled the engine and tore into it. It was the only spun bearing I found, the rest were nice and tight (although maybe they were about to let go too at any time).
Based on the photos below, is there any way to tell what type of failure occurred with this bearing? I'm wondering if the engine overheating damaged it and it ground itself down over the course of 15,000 or so miles. It was never run low on oil when I had it - although it did have pretty low oil pressure when warmed up, if the dash gauge was to be trusted.
