As some of you know from a previous thread, our old water heater was 28 years old. It was a Reliance 30 gallon gas unit and had no issues other than some surface rust. We chose to replace due to age / higher likelihood of failure. I did get 2 quotes from local companies, one quoted me $3,370 which was all in and included a 6 year basic 40 gallon gas unit. My second quote was from a family owned company with over 30 years of experience, it was $650 all in if I provided the water heater.
I already knew what unit I wanted, a Rheem Performance Platinum 40 gallon gas (12 year unit). I purchased it the same day as the quote and had it and just had it installed today.
The work that was done:
- cut out galvanized lines and replaced with Type-M copper
- installed water shut off valve (did not have this before)
- replaced gas line and gas shut off valve (previous valve was snapped and extremely hard to turn)
- installed an expansion tank
- routed T&P valve line outside
- put in new, up to code double walled gas vent
- put new heater on a stand
Needless to say I am VERY pleased with the service I received from this company.
So far the unit is running very well. With the old unit I kept the thermostat on "B" (choices being Low, Hot, A, B, C, Very Hot), now with this new unit I find "Low" to be more than hot enough. So this should translate into a couple dollars saved over time.
