I'm approaching the 40,000 mile service for my 2015 TDI Passat. I've done everything except the DSG already. I used the appropriate Castrol speced for my TDI added the Liqui Moly ceramic friction modifier. Did the fuel filter, and Liqui Moly diesel purge. OEM cold weather air filter, checked the pH of the coolant, and decided to keep it in, as it's 8.6 pH.
Please, if anyone had some insight into which DSG fluid is best for normal driving 50/50 city-highway. No track events, just want the best possible protection and smooth shifts. Thank you in advance
