NY Yankee fans...
by gfh77665 - 10/20/19 12:56 AM
168 inch pounds feels really--really tight
by perfect_oil - 10/19/19 11:36 PM
Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
Need tires for the mustang
by BeerCan - 10/19/19 03:24 PM
No sign of of oil sample at BStone :(
by 21Rouge - 10/19/19 02:45 PM
Carpet Shopping - Need Advice
by The Critic - 10/19/19 02:17 PM
Local Autozone clearance
by Soggydog - 10/19/19 02:05 PM
Two Fumoto valves
by otis24 - 10/19/19 01:17 PM
Hallj49803, Tralever, Jhams, gmguy57, jamie24874
69612 Registered Users
26 registered members (forged, 4WD, Falcon_LS, billt460, Duke, 4 invisible), 753 guests, and 18 spiders.
Topics296,198
Posts5,093,328
Members69,612
Most Online3,532
Jul 30th, 2019
What happened to this car? #5060159 03/31/19 09:46 PM
R
Rochev Offline OP
R
Kinda long but its descriptive. I picked up a V6 Mazda MPV that sat for 3 years. It ran and drove great, when I got it the CEL was on for post-cat o2. (Heater circuit not responsive) but after about 20 miles since it sat it started misfiring badly on cyl-1.
It had 1/4 tank of old gas. I filled it with 93, put in octane booster, seafoam, some mystery oil, drove 1 mile back home and it sat overnight.
Next day I took the manifold off to see the plugs, (also egr, intake, battery, myriad of vacuum lines etc). I checked cyl 1+2. Both looked good. I swapped the plugs to see if it'd misfire on cyl-2.
The valve ports and manifold were caked with gunk and carbon. I cleaned it using carb cleaner and a rag. Nothing fell into the valves.
When I tried starting it I knew it would stall a couple times. However it wouldn't run for 15 minutes. Then it would only run if I feathered the gas but rev to 3-4k and stall out.
Theres a delay with the throttle and response, it shakes and misfires and seems like its not getting fuel or air. Now it'll start and rev to 3500 rpm and idle around 200. Smells horrible, like carbon and bad gas.
When driving and slowing down it dies to 150rpm, shakes and warning lights come on because its basically off.
I adjusted the idle screw to keep the idle on 2k. Itll randomly rev high. Again, smells HORRID. I used Forscan and my scanner and nothing is coming up. I checked coutless times that everything is put back.
Could it be clogged injectors, fuel pump, fuel filter, vacuum leak? I cant figure it out!
Re: What happened to this car? [Re: Rochev] #5060164 03/31/19 09:50 PM
M
michaelluscher Offline
M
Check the throttle body and IAC valve, you might've disturbed something or knocked a chunk of carbon into something
This is a 3.0 Duratec 30 V6, same as a Taurus twin, Escape siblings, or later 500/Montego/Freestyle
So same issues with coil pack failure and sensitivity to vacuum leaks on the upper plenum or PCV apply
What fuel trims is FORScan showing you?
'06 Toyota Camry SE V6 3MZ-FE 124k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
Re: What happened to this car? [Re: michaelluscher] #5060168 03/31/19 09:54 PM
R
Rochev Offline OP
R
Thanks for the reply. It does seem like a massive vacuum leak. This is the older 2.5 but pretty much the same as the 3.0 with the setup. I'm heading outside soon to run Forscan again and will post what it says.
I should mention that it does drive ok and doesnt misfire on acceleration. Its starting, idling and slowing down thats having issues. There is a lack of power though, but not much.
Re: What happened to this car? [Re: Rochev] #5060229 03/31/19 11:46 PM
E
ecotourist Offline
E
Did you leave the old gas in and just add to it. Old gas can smell really terrible and nothing runs very well on it either. That could be your problem.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: What happened to this car? [Re: ecotourist] #5060263 04/01/19 12:53 AM
R
Rochev Offline OP
R
Yes it had just under a quarter in it. Thats what I'm wondering, if it was a coincidence that it acted up after i pulled the plugs because the old gas just screwed it up at the same time.
I took everything apart again and put it all back to make 100% sure. It started after the second try without me balancing the rpms. It ran ok but was stumbling still.
I bought two sets of different plugs and neither of them will start to thread in. I'm thinking a full tune up might fix it but as a yard vehicle im not sure i want to waste time throwing parts at it.
As for forscan, its currently not reading long term fuel trims, and short terms are all 0%. Not sure if its not reading things correctly or what.
Re: What happened to this car? [Re: Rochev] #5060265 04/01/19 01:30 AM
Nick1994 Offline
How's the flow out the exhaust?
My brother bought a truck that sat for some time, once it was running it would barely run and had no power, didn't want to rev very high. Turns out the catalytic converters was broken inside. Once that was fixed it turns out the muffler was plugged up from something living in it.
2015 Hyundai Sonata 2.4L 103k STP Synthetic HM 10w30 & OEM
2000 Toyota Camry 2.2L 235k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: What happened to this car? [Re: Rochev] #5060285 04/01/19 02:31 AM
G
Gasbuggy Online Happy
Online Happy
G
I dumped about 14 gallons of old gas in my Yukon once. It turned out to be older than I was told. Smelled like turpentine. Mixed in with 20+ gallons of fresh I kind of wonder how well old gas mixes with fresh because it ran fine that day (40 miles). But man, the following day when I started it up, it fired up fine and then not long after it started struggling. spark knock if you gave it too quick of a throttle input, low power, low idle etc. I tried topping off with 93 that day but it didn't balance out until I ran that tank most of the way out and refilled.
Cadillac CTS-V 6.2L 10w30PP
Volvo P1800 Euro L
76 Mercedes 300D Rotella T4
Series III Land Rover VWB
02 Yukon 10w30 PP
01 P71 M1 EP-HM 0W20
95 Accord - 386k. Mobil 2 RIP
Re: What happened to this car? [Re: Rochev] #5060378 04/01/19 07:15 AM
E
Eric Smith Offline
E
If it's the same as the Escape 3.0 and a vacuum leak look at the back of the intake. There's a fairly good size elbow that you won't be able to tell it's bad till you pull it off, I want to say it's for the PCV but I could be wrong.
05 Chevy 3500 (Class C RV) 66k
04 Escape 166k
02 Focus 145k
00 Dakota 93k
91 Festiva 257k .. Rust bucket
Re: What happened to this car? [Re: Rochev] #5060453 04/01/19 08:21 AM
A
addyguy Offline
A
Blocked/broken up cat convertors caused my EGR valve to keep blowing out on my Duratec. Did similar things yours is doing.
2010 Kia Soul 2U - 2.0L I-4, auto; 146k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: What happened to this car? [Re: Rochev] #5060505 04/01/19 09:12 AM
B
brages Offline
B
Misfires and bad smells on a Duratec 3.0 in a Mazda MPV strongly points to a bad PCV elbow on the back of the intake.
You can replace the elbow with a copper one from the hardware store and some heater hose for cheaper than the factory part, and it won't fail again.
http://forum.mpvclub.com/viewtopic.php?t=22333
(I owned one of these and it happened to me.)
Re: What happened to this car? [Re: Rochev] #5060508 04/01/19 09:15 AM
B
brages Offline
B
I'm assuming this is a second-gen MPV with the transversely mounted Duratec-based engine.
Re: What happened to this car? [Re: Rochev] #5061570 04/02/19 07:33 AM
R
Rochev Offline OP
R
This is a 2000 with the 2.5. I inspected the pcv elbow, had it leak on an old Taurus I had. Unfortunately the car sunk up to the rocker panels in mud, so i cant see if the cat converter is rattling. Its not throwing any new codes still.
Re: What happened to this car? [Re: Rochev] #5062252 04/02/19 04:18 PM
R
Rochev Offline OP
R
Im thinking it must be bad gas. Im hoping it'll run its course and smooth back out. I pulled it out of the mud and banged on the exhaust but didnt hesr any rattling.
Thanks everyone for chiming in!
Re: What happened to this car? [Re: Rochev] #5062481 04/02/19 08:40 PM
E
eljefino Offline
E
I had a ruptured fuel pressure regulator on a ford/mazda product. It was sucking tons of gas in the intake, and ran worse at idle b/c the ratio was waaaaay off then. You can check yours by just seeing if the hose is full of gas.
With the car having been parked then disturbed, you could have ruptured the diaphragm.
You should also check to see if the PRNDL switch is communicating properly-- it might not "know" it has to idle if it thinks its in the wrong gear.
Re: What happened to this car? [Re: Rochev] #5062559 04/02/19 10:09 PM
clinebarger Offline
Bad-Rotten-Varnished gasoline can cause sticky valves......Run a compression test on all 6 cylinders.
2001 Chevy Camaro L92/4L80E
