2019 Golf R
by wings&wheels - 10/22/19 06:47 AM
My latest battery load test
by Char Baby - 10/22/19 05:18 AM
MB Loctite 5970
by The Critic - 10/22/19 01:18 AM
Amazon Special on Lubegard LXE
by Marco620 - 10/21/19 11:42 PM
ATF Life in Sealed Bottle
by ZeeOSix - 10/21/19 11:34 PM
Pumpkin Pie
by kstanf150 - 10/21/19 11:18 PM
Delphi ecu and segment swap
by P10crew - 10/21/19 10:06 PM
Close Call!😨
by Mad_Hatter - 10/21/19 10:06 PM
12 bolt truck rear
by P10crew - 10/21/19 09:57 PM
More painful motorcycle hill climbing footage
by Reddy45 - 10/21/19 09:57 PM
Charging for parking
by madRiver - 10/21/19 08:59 PM
OxyClean car wash
by dawgn86 - 10/21/19 08:58 PM
Oil Catalogue Idea
by GaryPoe - 10/21/19 08:51 PM
Liqui Moly longtime vs 4605
by jkhawaii - 10/21/19 08:17 PM
Name a good alcohol wine/beverage for a beginner.
by Vern_in_IL - 10/21/19 07:06 PM
Pulling a bumper pull keystone outback
by ram_man - 10/21/19 06:54 PM
Another fuel mileage thread
by tiger862 - 10/21/19 06:54 PM
Winter Truck: RWD w/ locking diff OR 4x4 w/o locking diff
by PotatoFarmer77w - 10/21/19 05:36 PM
M1 ESP 0W30 (8200 km run for an 2018 VW Golf R)
by 21Rouge - 10/21/19 05:11 PM
TV_Viewer2, Finner, blimo, Haiducek, NoRegrets
69642 Registered Users
75 registered members (AndyB, 2002 Maxima SE, alarmguy, 2015_PSD, Aredeeem, 8 invisible), 1,413 guests, and 21 spiders.
Topics296,311
Posts5,095,396
Members69,642
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Champion COS10575 & COS10590 - C&P [Re: ZeeOSix] #5059734 03/31/19 04:11 PM
W
webfors Offline OP
W
Originally Posted by ZeeOSix
Originally Posted by webfors
Measurements in cm:
COS10575: 5.6 (P) x 2 x 1.2 (D) x 8.0 (L) =107.52
COS10590: 5.6 (P) x 2 x 1.1 (D) x 9.3 (L) = 114.58
Looks like the COS10590 is the winner by approximately 6.2% more media.
How do these measurements stand up to other filters?
Looks like you're off by 10 times - you used 5.6 pleats instead of 56.
1075 sq-cm = 166.6 sq-in.
That's a pretty good amount of media area.
Doh!
Corrected calculations:
COS10575: 5.6 (P) x 2 x 1.2 (D) x 8.0 (L) =1075.20 cm squared = 166.7 inches squared
COS10590: 5.6 (P) x 2 x 1.1 (D) x 9.3 (L) = 1145.76 cm squared = 177.9 inches squared
17 Cadillac ATS 2.0T, Edge D1G2 5w30, Champion COS10590
17 Dodge GC, VWB 5w30, Mopar MO-349
18 DL1000XT, Valvoline Dino 20w50, Suzuki OEM OF
Small engines; RT5 10w30
Re: Champion COS10575 & COS10590 - C&P [Re: webfors] #5059746 03/31/19 04:19 PM
W
webfors Offline OP
W
Now that we know the media area, what are the chances this won't flow well enough to make GM's 22psi bypass requirement a moot point.
Another thing I thought of recently, with the sudden increase in bypass specs, could this be related in some way to auto stop/start technology that has made its' way into every car?
Re: Champion COS10575 & COS10590 - C&P [Re: webfors] #5060012 03/31/19 07:58 PM
Z
ZeeOSix Offline
Z
Hard to say how these filters flow without actual "flow vs delta-p" test data. But since they are synthetic blend media and have a prettly large area, I'd say that they would flow very well. Changes of them bypassing is probably pretty remote under normal use conditions.
Re: Champion COSxxxx oil filters. Not shipped to California [Re: ZeeOSix] #5073233 04/13/19 12:57 AM
T
thrace Offline
T
Tried to buy champion oil filters but got this automatic response from RockAuto website:
"Part # COSXXXX cannot ship to California because we do not have documentation required by Proposition 65 from CHAMPION FILTER. Please choose a different brand.
I guess Champioon oil filters are not to be sold in California.
Re: Champion COSxxxx oil filters. Not shipped to California [Re: thrace] #5073255 04/13/19 02:14 AM
SlavaB Offline
No I think the deal is that they got it without the original package and documentation, hence they can't provide info regarding prop 65 to the government.
17 Kia Sportage EX 2.4 GDI / RP HPS 5w30, CQ Premium 85334
15 MB GLA250 4Matic 2.0T / Mercedes OEM 5w40, OEM filter
Re: Champion COSxxxx oil filters. Not shipped to California [Re: webfors] #5073935 04/13/19 07:27 PM
A
advocate Offline
A
Thanks for the c&p! I just ordered 8 of these cos10575’s to be used on my 2018 5.0 F150.
Re: Champion COSxxxx oil filters. Not shipped to California [Re: webfors] #5074000 04/13/19 08:46 PM
W
WellOiled Offline
W
Thanks for the well done C&P!!!
Mazda 6
Factory fill
Re: Champion COSxxxx oil filters. Not shipped to California [Re: thrace] #5074143 04/13/19 11:00 PM
P
Pinoak Offline
P
That's just because California sucks. And so who really cares lol
Re: Champion COS10575 & COS10590 - C&P [Re: webfors] #5074521 04/14/19 10:48 AM
P
Pinoak Offline
P
I picked up my $1.30 Champion filters, so I decided to cut a couple open. Hybrid media, good filtering efficiency, silicon ADBV, nice basic construction, and good strong media with strong bonding. Each filter had 56 pleats.
https://fme-cat.com/livedocs/Oil%20Filter%20Sell%20Sheet_052317.pdf
Differences between the two; I noticed the 10575 was heavier than the 10590, which was strange considering the 10590 being a larger filter. After looking at the cut open parts, it was the baseplate. The 10575 base plate was much heavier.
COS10575: has a traditional coil spring, which directly connected to the bypass valve. The media appeared to have a slight advantage with respect to how deep the media went before hitting the centre cage.
COS10590: has a leaf spring, with a bypass valve with internal spring/design. The media was more evenly spaced vs the 10575. There was some corrosion in the bottom of the can.
They both appeared to have about the same pressure relief when I tested them with the trusty pen grin
I feel ok using these in the Cadillac for the ~5k they will see. I know I said I was done with paper filters, but I'm really starting to not care as much about this stuff as I used to. Must be the age. These are definitely an upgrade from the OEM PF64.
Enjoy the pics:
https://www.dropbox.com/sh/io7eyrnf9zfvv76/AADWfXLholqT7xZkh7pCpMA7a?dl=0
I'll cut and paste them as they are used over the next couple of years.
I think those are similar to M1 filters and are synthetic blend. I'm with you though in that I think paper media can do just fine for 5k.
Page 2 of 2 1 2
