Originally Posted by Ws6
Originally Posted by ndfergy
To have a grade of 27% over a run of 350' you would need a rise of ~100'. Clearly that's not the case so something is amiss. Your photo suggest something like a 3 -> 5:1 vehicle/crest ratio depending how far away from the base you're parked. 16 to 25 feet rise? There must be a severe slope change or distance error in your run to explain this. Photos can be deceiving.
Nonetheless, I'll take your word for it but maybe you're confusing a 17% grade with 17 degrees of inclination? Either way AWD is the wise choice. Most certainly if the latter.
Nice All-Season tires. They would give my winters a run for the money.
I don't own an altimeter, but I do own a smart-phone with an "inclinometer", and it was reading around 17 degrees.
As to the Nokians, I found them to be pretty bad at everything and will never own another set from that company. Cheap trash. They were done before it even snowed, down from new to 32 by 19K miles (19k miles of rough, un-balanceable, slip-and-slide-in-the-rain, loud and obnoxious torture.) I replaced them with Altimax RT43's, and was VERY pleased. My current CX5 has Toyo A36's, and when those die, it will get the RT43's, as well. I have never seen a [censored] product MORE recommended than Nokians. I feel wronged for having owned that cheap trash, lol!
The rise is much more than 16-20ft, as when I am standing on the roof of my 2 story house, I am not even close to seeing over the crest of that hill. I have 18ft ceilings, and the floor is a good 6' off the ground, and the roof extends a good 5' above the crest of my vaulted ceilings, and I stand 5'11", on top of THAT.
https://scontent-dfw5-1.xx.fbcdn.ne...445917e5261ca21684eadf7c&oe=5D0DB7C3
*The above photo was taken by me, standing, at approximately 75m from the house. Even at that angle, you can see hill behind it.
Per the topo map (Google), it's about a 40ft elevation change between the top and bottom of the hill, and the distance is @ 220ft. Again, this is from Google maps. I walked it out to be around 300ish ft, but when measuring distance on Google, it is straight-line only, not counting elevation. Also, I did not use a measuring wheel, but rather just "paced" it, and was pacing it for consideration of paving, and do not recall if I measured past the actual slope, or not, for that purpose.
Nokian is doing some false marketing. Those tires are actually snow tires. That is how they market in Europe It basically has snow tire compound, but they sell them in the US as all weather (or all season, cannot remember). They should not be driven outside of winter months. And yes, they will have short lifespan.
I have their R2 Hakka on Tiguan, and they are superb in deep snow. However, like you said, absolute trash in every other application. I highly doubt they will last 15k. Though, they are hardcore snow tire and that is kind of expected.
