Originally Posted by AMGTHIS
Hi guys ever since I started using mann oil filter over genuine filter the engine seemed much quieter so I kept using them but recently my bmw started to make a ticking noise when accelerating from a stop. Took my car to the dealer as it's still under factory warranty and they couldn't find the cause so now there having a rep from bmw come and make a decision on weather I need an engine replacement. Mann is suppose to be oem for bmw if Im not mistaken but can it be possible due to the filter not being genuine bmw I get red flaggged and warranty voids? Thanks..
This is unfortunate. I hope it works out for you.
There have been incidents with the oil filter not being the correct type, such as the proper protrusion missing, that resulted in engine damage. If they determine that the oil filter you bought was of the incorrect type, they will void your warranty.
Otherwise, they can't void your warranty for properly installing the correct aftermarket oil filter.
So, unless there is a situation like the following, things should work out. The driver had bought a MANN-FILTER oil filter without the protrusion from Amazon, with the correct oil filter being one with the protrusion, and had it installed at an oil-change place. I doubt this is what happened in your case though. Again, if the oil filter was of the correct type and installed properly, being aftermarket is a nonissue.
https://www.bobistheoilguy.com/foru...67607/all/Wrong_OEM_oil_filter_ruins_Mer
CHECK ENGINE LIGHT IS COMING ON
WRONG OIL FILTER
HOOKED UP SDS AND BATTERY CHARGER PREFORMED QUICK TEST FOUND CODE IN ME
P054A00 THE POSITION OF THE EXHAUST CAMSHAFT (CYLINDER BANK 1) DEVIATES FROM SPECIFIED VALUE IN DIRECTION OF ADVANCE DURING COLD START
NOTICED THAT WHEN PULLING CAR IN THE MOTOR WAS UNUSUALLY LOUD
CHECKED OIL LEVEL AND FOUND TO BE SLIGHTLY OVER FULL
CHECKED OIL FILTER AND FOUND WRONG OIL FILTER INSTALLED
THE OIL HAS A SILVER SHEEN TO IT BECAUSE OF INTERNAL DAMAGE DUE TO WRONG OIL FILTER.
INSTALLED PROPER OIL FILTER AND CLEARED CODE
ENGINE IS QUIET NOW BUT YOU HEAR A SLIGHT BOTTOM END NOISE
GAVE ESTIMATE FOR ENGINE REPLACEMENT
CUSTOMER DECLINED REPAIRS AT THIS TIME
THE OIL FILTER THAT WAS INSTALLED ON THE CAR WAS FOR A 272 ENGINE THAT WAS IN THIS MODEL UNTIL 2012 THIS CAR HAS A 276 ENGINE
