TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
18 registered members (bbhero, Char Baby, CatCam2, 2015Corolla, AnthemBassMan, ctechbob, 2 invisible), 1,119 guests, and 31 spiders.
Topics306,033
Posts5,285,252
Members71,566
What's in Maxima oil? #5052092 03/23/19 06:29 PM
T
Truckedup Offline OP
T
I posted this above in the oil analysis forum, but it is bike oil....20/50 Maxima Pro Plus ester base synthetic..Costs about $36 a gallon shipped to my door..I'm trying it as an alternative to the more expensive Mobil V Tin in my 96 900 Ducati and 79 Triumph 750..
[Linked Image]
World's second fastest vintage Triumph 650, 133 MPH
Re: What's in Maxima oil? [Re: Truckedup] #5052108 03/23/19 06:59 PM
O
oil_film_movies Offline
O
Great flashpoint. Might be the highest I've ever seen. That's from the POE (polyol ester) of course. This stuff is meant for high temperatures, to resist oxidation best. They use POE in jet engine turbines.
Zinc and phosphorus look right, typical here. Calcium is a bit on the low side, but I'm sure its enough for this application.
Lack of moly tells me this might work fine in a wet-clutch shared sump arrangement. JASO MA2 I'm seeing.
Maxima describes it as a "full syn, ester fortified" formula, so maybe lots of PAO to go with some POE in there, not all POE.
Re: What's in Maxima oil? [Re: Truckedup] #5052192 03/23/19 08:51 PM
R
Reddy45 Offline
R
I'm currently running Maxima Extra 4 15W50 in my Triumph Tiger 800 and will post UOA results after a solid 6k miles on the oil (factory interval spec). I believe Maxima makes solid oils.
Re: What's in Maxima oil? [Re: oil_film_movies] #5053389 03/25/19 09:10 AM
sunruh Offline
this shows you really don't understand moly
motorcycle oil myth buster
Re: What's in Maxima oil? [Re: sunruh] #5053493 03/25/19 11:14 AM
T
T
Explain......It appears to me, not a oil engineer, that most or all Jaso bike oils have little to no moly..?
Re: What's in Maxima oil? [Re: Truckedup] #5056288 03/28/19 01:31 AM
stoan Offline
Red Line motorcycle oils are loaded with moly, way more than most auto oils have.
Re: What's in Maxima oil? [Re: stoan] #5056362 03/28/19 06:46 AM
T
T
Yes, Redline website claims 400 ppm moly in their 10/40 motorcycle oil....So what goes on? Not all moly is equal?
Re: What's in Maxima oil? [Re: Truckedup] #5057272 03/29/19 03:16 AM
DoubleWasp Offline
Maxima has amazing shear resistance. Good formula going on there.
Re: What's in Maxima oil? [Re: Truckedup] #5058882 03/30/19 07:24 PM
J
joe02151 Offline
J
how many miles were on this
Re: What's in Maxima oil? [Re: joe02151] #5059211 03/31/19 06:38 AM
T
T
I may have filed to restate it's a virgin oil sample
Re: What's in Maxima oil? [Re: Truckedup] #5059277 03/31/19 08:37 AM
Degreaser Offline
There's Molybdenum in the Shell Rotella oils, the T4 15w40 CK-4 conventional has (4), the T5 15w40 syn-blend has (68), and T6 5w40 syn has (60), RedLine 5w40 syn has (570), and Valvoline 15w40 Max-Life has (63) moly
Edit: the Rotella T5 15w40 syn-blend does not show the JASO MA/MA2 on the label, the T4 15w40 and the T6 5w40 syn does show on the label, not sure if JASO shows on RedLine or Valvoline bottles
Canada
Re: What's in Maxima oil? [Re: Truckedup] #5059291 03/31/19 08:55 AM
Degreaser Offline
The Maxima Premium 4 20w50 numbers look very good to me, Flash Point (475) is high which is good, high in the detergent Calcium (1881) but it's low on the acid neutralizer Magnesium (7), the Phosphorus/Zinc are anti-wear agents, the only concern I have is the weight (20w50), do you have an air-cooled bike that runs hot? I am wondering if you need a 50 weight oil in your bike
Canada
Re: What's in Maxima oil? [Re: stoan] #5059334 03/31/19 09:28 AM
Degreaser Offline
The Red Line 5w40 full syn has Molybdenum (570) which does seem very high for using in a wet clutch bike, in contrast the Shell Rotella T5 15w40 syn-blend has Moly (68) and Shell did not put JASO MA/MA2 on the jug label, but maybe moly (68) was not the reason, dunno
Canada
Re: What's in Maxima oil? [Re: Degreaser] #5059407 03/31/19 10:47 AM
J
jeff78 Offline
J
For acid neutralization, you'd want to look at the Total Base Number (TBN). It's blank on the report because Truckedup didn't pay extra for the TBN analysis. The number will start out at something like, say, 9 for a virgin oil, and decreases as the base is used up. So on a UOA of the same oil it may drop down to 6.
Re: What's in Maxima oil? [Re: Truckedup] #5062769 04/03/19 07:39 AM
sunruh Offline
Maxima oils have tested at or near the top of all of my 90+ uoa tests. they are very expensive and are pretty darn awesome!
