The motor guy
Thread starter
- Joined
- Nov 29, 2009
- Messages
- 7,265
Originally Posted by DoubleWasp
If your intake manifold has an exhaust crossover, that is the first thing that needs to go. Easy way is to use one of the FelPro intake manifold gasket kits that includes stainless restrictors and block-offs for the crossover. I've watched water boil off of the intake manifold where the crossover comes through.
Phenolic carb spacer or the "thick" carb gasket (if Quadrajet) is the next thing to do.
Your carb engine almost certainly does not have a fuel cooler, so I wouldn't worry about that.
Unless you have some serious restriction in your fuel lines, I wouldn't worry about that or insulation. Your engine doesn't have bare exhaust manifolds glowing with exhaust heat. You also don't have an engine bay baking with 200° heat after shutdown like a car.
I think it does have the crossover. There are two spots on each side if the manifold where the paint is flaked off from the heat. It's really rusted in that spot too. It does have a thick black gasket at the bottom
