Originally Posted by das_peikko
I turned on the hazard flashers. I think that's what you're supposed to do to see if all the bulbs light up. The two front signals are blinking. The left rear is blinking. But the right rear stays lit up solid. I haven't found any burned out bulbs yet.
That is not the right way to test if the right turn signal bulb is burned out. Just put the ignition switch in the run position and activate the right turn signal. Then walk back and look to see if it is working. By putting on the hazard flasher, most domestic cars will constantly illuminate the low intensity filament and intermittently flash the high intensity (brake light) filament. I'll bet the high intensity filament is burned out but the low intensity filament is intact. To prove this, swap the left rear bulb with the right rear bulb.
