I had a stuck zerk behind the muffler going up to the steering gear I think on my lawn tractor. changing the zerk did not help. An older man told me to probe the hole with a sharp tool, and when is was warmer, I could grease the gear! I haven't tested to see if the old zerk is still ok, but I will. so, try probing above or below a stuck zerk and see if that helps.
