Problem is that the CCS is the big shear cranking simulator...so in theory the above IS possible.
However the pour point test drops the temp in three degree increments, until a temp is reached that the surface doesn't move when held on the side for 5seconds...I.e. pourabity...then go back to the last three degree number that it poured at and ther's your number....as the CCS is a high shear rate, the wax is dispersed, and the above can happen, especially in that three degree bracket.
Problem is that MRV is the measure of pump ability, and it,s at -40C...PLUS it cannot have a yield stress, I.e. can,t be gelled enough such that the rotor is stalled and has the break away to get the wax moving.
There,s no chance in the world that an oil that has no surface movement at -36 or 37C can ever achieve the MRV of a 0W grade
