Pretty sure that PP's formulation changed pretty substantially with d1G2, but it should be of no concern for a Pentastar.
What you want to do would probably be somewhat like mixing M1 and PP a few years ago...which is just fine for your application.
If you had a direct injected turbo engine...well, you'd probably still be fine with the mixing, but I'd recommend using the newer oil only as a safety measure.
