ROFL..uh no.
#1 Low profile tires allow the use of wider tires which provide more grip used for handling and acceleration.
#2 Low profile tires are multiples more responsive than taller tires because there's less flex in the sidewall.
#3 Suspension tuning has a lot to do with how well a car rides on low profile tires.
Yes many do it primarily for looks.
Of course if you have to drive on garbage roads because salt/plowing/ice chew them up that's another issue separate of tire choice.
#1 Handling and grip for acceleration is pointless when you're stuck in bumper to bumper traffic going 15-20mph. More grip for what? Plus wider tires will make you float in rain/snow.
#2 More responsive for what? Most people can't even handle the handling that comes stock.
#3 There's only so much you can do with the suspension when you lower it, there's just not as much suspension travel and most people who do it aren't engineers so they certainly didn't do the engineering analysis that the factory does.
The fact of the matter is that many roads in this country are garbage so the fools who love the look end up forcing those who don't like it with the look. It does look like some manufacturers were coming to their senses as I'm sure there were too many people who complained about flat tires and bent/cracked rims. Maybe the other reason manufacturers liked it was because it kept their service shops busy.
Sorry, I probably sound like an old man yelling at the clouds.... (Just had to buy two more 18 inch rims for cracks in my Mercedes)
#1 When your vehicle is pushing over 100hp/liter you'll want better grip and handling for those times you're not stuck in rush hour traffic. Wider tires do NOT make you float in rain. That's just silly. Wider tires improve braking as well !!!
#2 Responsiveness is irrespective of need.
#3 So what. Outside of factory calibrated suspension for factory low profile tires what does it matter what "most people" do? A properly tuned suspension can remove a lot of the harshness from low profile tires.
The fact of the matter is that low profile tires not only provide better grip for handling, acceleration, and braking they also provide room for larger brakes which in almost all cases means better brakes. Sounds like your crying over the fact that you're not the target market of a vehicle you'd like to own save for the low profile tires. Cry me a river. Buy something else or move to a place with better roads.
There are very few times when you need better grip and handling on the public roads driving at legal speeds. You need to drive to the condition of the roads. If you really do need them, you should probably be on the track.
Better brakes are meaningless when you can easily cause them to lock up. Once you're at the maximum of static friction, you transition over kinetic friction which is the point of ABS. Then it's just up to the tires. Wider tires mean you're more likely to hydroplane in the rain but you get better braking in the dry. It's a compromise. You are just adjusting for better braking in dry for worse performance in the rain/snow. You can't have both.
https://www.bridgestonetire.com/tread-and-trend/tire-talk/hydroplaning
Tires are basically a trade off in terms of the various compromises that are made. As for it being properly tuned, that's probably one of those things where it's more of a theory than reality as most people doing it for looks have no clue about the engineering. Good luck trying to convince an engineer that the trade offs are worth it. It basically boils down to looks. From a cost and daily driving perspective, they're a waste of money.
Here's what you just said,
Even though Car X has a shorter 60-0 than Car Y, it doesn't matter because brakes lock up so quickly.
A 225/65/16 tire is better in the rain than a 225/40/18.
My god, the amount of envy around here has no bounds.
Why not just say, "I can't stand large rims with low profile tires because they're expensive to run, and the factory uses really heavy rims"
