*The best way to apply appears to be after washing & rinsing vehicle to apply lightly while vehicle is still wet - then rub in with a micro fiber towel until vehicle is dry .
Originally Posted by PimTac
The biggest problem with these products is with the user. The trick is to spray a light mist on the panels. Using good quality microfiber towels helps. Spraying too much on is a common mistake.
