Topics298,346
Posts5,133,509
Members70,043
Most Online3,589 Nov 2nd, 2019
Re: "The new" Mobil 1 Racing Oil ?
[Re: lawnguy]
#5052637
03/24/19 10:21 AM
PimTac
Posts: 11,653 |
No.
Pick a good oil to start with. No need to try to improve what has been researched and tested to meet strict standards. That is folly.
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
[Re: lawnguy]
#5052647
03/24/19 10:27 AM
A_Harman
Posts: 7,616 |
It's weird stuff. Why does a racing oil need a TBN of 9.9? Does it need the sky-high zddp content because it has such high TBN? Why formulate a racing oil that can meet 0W low temperature specs? Then how much VII does it have that may make it prone to shearing in continuous high-rpm operation? There are other Mobil 1 blends that have higher flashpoints, and possibly lower NOACK numbers. About the only use I see for this oil is to boost Moly and ZDDP in other oils as an additive.
2008 Dodge Ram 3500 diesel/G56 1985 Z51 Corvette track car 355/6-speed 2002 Camaro Z28 LS1/6-speed 2001 Dodge Ram 2500 diesel/NV4500+GV 1972 GMC 1500 shortbed project truck 307/SM465
[Re: lawnguy]
#5052695
03/24/19 11:32 AM
RDY4WAR
Posts: 857 |
I wouldn't use it by itself. I especially wouldn't want to blend it due to possible incompatibility issues. As mentioned, the ZDDP level is way to high for street use. At those levels, it's actually corrosive and can cause spalling problems. From what I've gathered, ZDDP should not exceed ~3%(wt, ~1920 ppm zinc) of the total oil composition for a street engine.
I'd run M1 FS 0w-40 long before I'd consider using this oil.
"He who is without oil, shall throw the first rod." - Compressions 9:1
[Re: lawnguy]
#5052738
03/24/19 12:09 PM
s2krunner
Posts: 288 |
2018 Chevy Camaro 6.2L V8 2017 Ford Explorer 3.5 V6 2011 Ford Ranger 4 banger
[Re: lawnguy]
#5052745
03/24/19 12:19 PM
benjy
Posts: 1,992 |
the word RACING is thrown around a lot incorrectly, that oil like Redlines real RACING oils are just that meant for racing with a lot of protective additives but little for longevity!!
[Re: benjy]
#5052757
03/24/19 12:32 PM
RDY4WAR
Posts: 857 |
the word RACING is thrown around a lot incorrectly, that oil like Redlines real RACING oils are just that meant for racing with a lot of protective additives but little for longevity!! Exactly. Driven XP line of oils as well. Total detergent package is less than 500 ppm, over 10% POE content, and entirely short-chained C4 secondary ZDDP with a TBN less than 2. It wouldn't last 500 miles on the street.
[Re: lawnguy]
#5052872
03/24/19 03:08 PM
ARCOgraphite
Posts: 13,907 |
Used to use M1 R 4T when it was "real" synthetic and it was a worth while "oil booster". An SG style real PAO syn.
Who is first with the frankenbrew? Someone with a stressed 5W30 application. My new Jetta is leased I cant even change the oil on it. - even if I wanted to. Plus VW 508
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
[Re: 4WD]
#5053866
03/25/19 03:30 PM
dailydriver
Posts: 9,614 |
Too much calcium for my DI engines … That's way too much calcium for a RACING OIL as well!  I wonder WHY they do that, as well as WHY they feel that the old dimer type of moly (obvious from that quantity) is better in a racing scenario than a (much, like ~400-500 ppm) higher than SN/SN+ level of the newer trimer type moly.
2016 Ford Fiesta ST 17K miles Ravenol REP 5W-30 Fram XG3600 filter Ravenol MTF-2 in the IB6 transaxle
[Re: dailydriver]
#5054216
03/25/19 10:45 PM
RDY4WAR
Posts: 857 |
Too much calcium for my DI engines … That's way too much calcium for a RACING OIL as well!  I wonder WHY they do that, as well as WHY they feel that the old dimer type of moly (obvious from that quantity) is better in a racing scenario than a (much, like ~400-500 ppm) higher than SN/SN+ level of the newer trimer type moly.  Probably so much calcium because they know people are going to dump it into their street car, and they want to CYA. The same reason Valvoline does it with VR1. Also, that high level of moly doesn't mean it's old MoS2. The Driven XP line of oil I posted about above has similar moly ppm and it's a blend of tri-nuclear and organo-moly.
[Re: lawnguy]
#5054283
03/26/19 01:42 AM
Garak
Posts: 28,128 |
In something "old" I might.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, Wix 57356 1984 F-150 4.9L - Quaker State GB 10w-30, Wix 51515
[Re: dailydriver]
#5054451
03/26/19 07:47 AM
bluesubie
Posts: 2,394 |
... as well as WHY they feel that the old dimer type of moly (obvious from that quantity) is better in a racing scenario than a (much, like ~400-500 ppm) higher than SN/SN+ level of the newer trimer type moly.  Maybe because, Infineum papers aside, the dimer type actually does have better friction modification properties than the trimer type.  Old school FTW?
'20 Subaru Outback Onyx XT | FF Idemitsu 0W-20 '04 Subaru Forester 2.5XT | Edge 0W-40
[Re: bluesubie]
#5054459
03/26/19 07:59 AM
PimTac
Posts: 11,653 |
... as well as WHY they feel that the old dimer type of moly (obvious from that quantity) is better in a racing scenario than a (much, like ~400-500 ppm) higher than SN/SN+ level of the newer trimer type moly.  Maybe because, Infineum papers aside, the dimer type actually does have better friction modification properties than the trimer type.  Old school FTW?  This would be a good discussion on its own.
[Re: lawnguy]
#5054568
03/26/19 10:29 AM
ad244
Posts: 489 |
[Re: bluesubie]
#5054810
03/26/19 02:58 PM
dailydriver
Posts: 9,614 |
... as well as WHY they feel that the old dimer type of moly (obvious from that quantity) is better in a racing scenario than a (much, like ~400-500 ppm) higher than SN/SN+ level of the newer trimer type moly.  Maybe because, Infineum papers aside, the dimer type actually does have better friction modification properties than the trimer type.  Old school FTW?  HMMMM, makes me wonder what type Ravenol is using (I'm gonna guess trimer  ), and IF the above is correct, it makes me wish that Red Line would come up with a low calcium/high magnesium, but high dimer moly add pack content product, all the more.
[Re: RDY4WAR]
#5054838
03/26/19 03:23 PM
ekpolk
Global Moderator
Global Moderator
Posts: 9,427 |
. . . Probably so much calcium because they know people are going to dump it into their street car, and they want to CYA. The same reason Valvoline does it with VR1. . . . Well, learn something new every day. I never even considered the idea that oil makers would have to "adulterate" their racing oils to protect delusional drivers who have convinced themselves that they somehow "need" racing oil instead of proper street oil. . . Wow. Maybe if I fill my Prius with M1R, I'll be able to beat a Corvette from a stoplight! He'll never see it coming! Maybe racing oil should be available only with a certified mechanic's prescription! Better still, make a "racing oil prescription" a "double signer" -- first your mechanic signs off, then your psychiatrist has to approve!
18 Prius Two-Eco (L-Ion Batt), Mag Grey, 4000 miles (M1 AFE 0W-20). 07 Avalon XLS, Cassis Pearl, only 70k miles (M1 EP 5w-30). 04 Prius, Black, 200k miles (M1 EP 5w-30). 2006-2019 --RIP 😥
