2015 Dodge Challenger 3.6L Pentastar with 98,xxx miles, It's an Auction car brought in by one of the used car lots we do business with.
The rear #3 Intake Valve Springs is broke.....I heard it "Huffing" through the air filter housing & the first thing I did was install a Vacuum Gauge! It bounced rabidly between 17 inches of Vacuum & 2 psi.
Hooked up the scan tool & showed a P0300 & P0303.....I expected a MAP sensor performance DTC to be included but P0106 isn't supported?
Pulled the valve cover & sure enough.....Now I had to prove-out that the valve isn't bent.
*Barred the engine 'til all #3 valves were closed, Had a helper hold a breaker bar on the crank bolt while I introduced air via my Leak-Down regulator while pulling up on the spring retainer with a Awl.....No dice as the lash adjuster was pumped-up.
*Removed the rocker arm using a special tool called a flat blade screwdriver.
* Re-Introduced air pressure, But didn't have my Awl positioned right ....Instead of backing off the regulator like I should have. I just re-positioned my Awl & scared the "S" out of my helper when the valve sealed
*Excellent leakdown percentage at 80 psi.
